Question about Cobra 29 LTD CB Radio
POWER CORD COBRA 29 LID CLASSIC. RADIO IS TURN OFF. WHEN YOU PUT THE POWER CORD ON. THE RADIO WILL LIGHT UP. THEN IT GO OFF. IT WILL POWER UP AND WORK OK
  • 1 more comment
  • bacbdude46 Jan 08, 2009
    THE RADIO IS TURN OFF AT THE SWITCH. YOU PUT THE POWER CORD TO THE RADIO .THE RADIO WILL LIGHT UP 4 ABOUT 3 TO 4 SEC. THEN IT WILL GO OFF. YOU TURN THE RADIO ON THEN IT IS [ OK ] NOW.
  • Lil Spark May 11, 2010
    have the the turn on/off switch checked
If you have a cobra 29 with weather band, it is capable of turning on by its self when important weather info is posted. It is normal to hear it turn on and off. The fix for this is power it up directly and dont forget to turn the switch off when you are done using it.
Posted on Sep 09, 2009
    Problem Solver:
  • 6 Answers
Check your ground wire and make sure it is getting a good connection because if not you will keep blowing fuses after a while
Posted on Aug 30, 2009
My cobra 29 classic wont turn on
polarity protection diode near power input burnt.
Apr 14, 2013 | Cobra 29 LTD CB Radio
Cobra 29ltd CLassic, TX power and audio is ok, volume from spkr is good, squelch works but no cb recieve.
Try a new Mic. Make sure its a working mic. If you have a bad mic, the receive will not work.
Aug 22, 2010 | Cobra 29 LTD CB Radio
I have a Cobra 29 NW LTD Classic I have power going to radio but no power when i turn on knob. i have looked inside for a fuse but can not find one.
did you look for power comming out of your power switch....
dont tell me that you hooked it up backwards. if you did check the imput diodes
Aug 29, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd classic ant light
Your SWR is probably NOT fine. You need to use an external meter if you have had work done to the radio. Especially if you have had a swing mod done to the radio. When you do this, the dead key of the radio is lower then the calibration knob on the radio can adjust for. It will always come up lower then it actually is.
Your radio might have been fine before the work was done on it because it was putting out very little power. Now you are most likely putting out 50 watts or more. Big jump from 4 watts.
When your raise the power in a radio, you will notice more when the antenna is not properly tuned.
In most cases with a stock CB, even when the antenna is not even near tuned, you will get a reading less then 1.5 anyway.
the more power you put out, the more important it is to have a good match.
But an external SWR meter, and check it. be careful if the ANT light is on.
You might also want to check your coax, connections to it, and your antenna for anything wrong.
Apr 22, 2009 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra 29 issues
Check D23 and D28. They are polarity protection diodes. It could also be the power knob.
Nov 09, 2008 | Cobra 29 LTD CB Radio
Cobra 29 ltd nw classic
Yes, Do Not Turn Up Too 500's Way Too Dangerous, The Problem Might Be That Inside Some Cords May Be Rubbing Wrong Or, You Have A Short Cord, If Not Any Of That It Is Probally Broke
Aug 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
Mar 19, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
113 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
