Question about IBM ThinkPad T30 2366 Notebook
Can only just see image on screen
My compaq c500 LCD screen ios not functioning correctly. The image is only just visable. I have tried changing the power inverter and display ribbon. Is there any way to test is my screen is defective before i purcase a new screen. The laptop works fine when remoted through a standalone screen so i assume there is no mother board issue.
  • 32 Answers
The issue may have been with the inverter/lcd in tandem. One shorted the other out, or vice versa. You may need to replace both at the same time. I am currently working on a laptop which is having the same issue. We tried the new inverter on the old panel, the panel lit up for a second and then went out again. Upon replacing both at the same time, the issue is resolved. I can only suggest you do the same, however I do know how expensive those panels can be (500-1300 just for the panel!!)
Posted on Jan 08, 2009
    Scholar:
  • 35 Answers
COMPUTER WON'T COME OUT OF UPDATE MODE
It possibly has not finished updating. Is it Win XP? They can take 12hours sometimes. Re boot and windows will try again.
Aug 21, 2013 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
My compaq presario c500 laptop keyboard isn't
only one way change the keyboard with new one. or use ans extrnal usb keyboard
Feb 02, 2013 | Computers & Internet
Don,t remember old password for a compaq pc need to removed it
You cannot remove a password without typing it first That is why there is a password!
Dec 04, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
Compaq presario c500 has power and charges but the screen stays off disks will eject and you can hear the computer running just nothing on the screen.
hi there,
Please have it plugged it onto an external monitor to make sure that the problem is not with the LCD. Is there a backlight on the LCD or is it totally dark?
If the external monitor gives out an image it means that the LCD might be busted but do you know the keyboard shortcut to switch between the external monitor and the laptop screen?
You can try FN+ F5. if that does not work you definitely have to try it out on a external monitor.
May 30, 2011 | Compaq Presario Notebook
I need a screen for the lapta laptap for a compaq c 700
From a quick search on the internet,
http://www.buy.com/prod/compaq-presario-c300-c500-c700-15-4-lcd-screen-glossy/q/sellerid/23890586/loc/101/211871209.html
http://www.screentekinc.com/Compaq_Presario_C700_Series_C731TU--15.4-inch-laptop-lcd-screen.shtml
Need the Service Manual? (Free)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go down to the line that starts with Compaq Presario 1100, then go across to > C700, and click on it.
This is a PDF file. After you click on C700 you may not see anything happening for up to 30 seconds. The file is downloading in the background.
After you see the first page come up, I suggest you let the file download all the way before looking through it.
(Took 7 seconds for the first page to come up, and an additional 53 seconds for the file to fully download, just now.
I'm using a medium speed DSL connection)
Page 55 - Display assembly
1) Work on a table
2) Observe Anti-Static Precautions.
3) Use a multi-compartment container for the various screws you will remove.
Mark the compartments for the area the screw/s came out of.
Do NOT mix them up!
If no multi-compartment container is available, you can use a clean egg carton. Mark the egg holders.
4) When you remove the LCD screen, look at the back. Write down the manufacturer name, and part number. Match it up to the one you're going to buy. Make SURE it it is the correct size.
(The screen is measured diagonally. From corner to corner)
If the screen is dark, and there is no apparent physical damage to it, do not assume the problem is the LCD screen.
Laptop on use a flashlight to see if you can see faint images.
If so, 90 percent of the time the problem is a bad Inverter.
A small circuit board located at the bottom of the Display assembly, and behind the Bezel.
MUCH cheaper than an LCD screen.
If you need guidance in replacing the LCD screen, or Inverter, and would also like some tips, post in a Comment.
Regards,
joecoolvette
Nov 22, 2010 | Compaq Computers & Internet
LCD of Compaq c500 needs replacement
Your best bet is eBay. They're at wholesale prices and if you can do it, it will only cost you the price of the screen. Just put the model number in eBay and a list of screens will come up.
Dec 09, 2009 | Compaq Presario Notebook
Image moves 2 " down when printing through adf in only legal size
Enter service mode > additional functions 2 8 additional functions >select feeder > funtion tab> set adf guides to legal settings > select TRY-LGL on the lcd display> select ok>
test if not corrected
then
select adjust> DOCST > use keypad to set adjustment value> select OK
select LA-Speed> use keypad to set adjustment value> select OK
Remember to write down the original values before changing them in case you need to set them back.
Jul 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
No sound,modem and wireless assistant for my compaq presario c500
You didn't mention what OS you are running but this link will take you to the main driver page for the c500 on HP's website.
Please post your results back here, especially if you have problems finding/installing the drivers for your unit and need additional assistance.
Mar 31, 2009 | Compaq Computers & Internet
Distortion of images on my laptop screen
i may be due to over heating of components like heat sink. or the problem with the connecting display cable. check it out
Jan 08, 2009 | Compaq Presario Notebook
Compaq laptop pink screen sometimes
The normal cause of a pink tinted screen is that the LCD back light is beginning to fail. Kind of like a regular florescent bulb does when it starts to go bad. It may last for a while, but eventually you'll have to replace it.
Ron
Dec 13, 2008 | Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
59 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
