Question about Clarion DXZ945MP CD Player
Kicker zr240 amp sound shut off and on while driving.
  • BigMatt1996 Jan 06, 2009
    The ground wire is mounted to my fuel pump ground in the base of my trunk. If the ground was lose wouldn't the amp power light turn off?
    The protection light does not flash or come on. I have had the amp for 10 years now and that light would always turn on when it got hot.
    The crossover that is in it now it the SWX. I do not think this was the original crossover that it came with. I thought I had one go bad on me when I first bought the amp years ago so that was my first guess as to why it seems to shut off and on.
  • blueextc3221
    blueextc3221 May 11, 2010
    sounds like a loose wire.
    But please check all of the following and re-post....
    Positive wire & post at battery tight?
    Main power wire Fuseholder Secure to wire @ battery?
    Ground for amplifier sanded & tight?
    Positive, Ground, and 12V turn on wire all secure at amplifier terminal?
    Any indicator lights (protection) on the amplifier coming on?
2 Suggested Answers
SOURCE: kicker zr240 amp
I doubt it is loose solder joints...im sure it is just a bad connction between that junk crossover and the even crappier amp. Try just cleaning the connection points with rubbing alcohol or something and see if that works...if not, try building up the flat male side of the connection with a tiny hint of solder and force it to connect...if that doesnt fix your problem...throw that POS away and buy a real amp!
Posted on Jun 04, 2009
Kicker SX900.2 turns on then says overload and shuts off
Sounds like one or more of the output transistors have gone and the amp protects itself from any further damage.
May 06, 2012 | Kicker Car Audio & Video
Zr240 kicker amplifier. how many watts is it
  • 60 watts x 2 at 4 ohms
  • 240 watts x 1 in bridged mode
  • 120 watts x 2 at 2 ohms
  • Dec 23, 2010 | Kicker Car Audio & Video
    Tuning my Kenwood 1000watt and also a Kicker zr240 for best sound
    It all depends on the type of music you listen to. I fyou listen to music that consistently produce low frequency sound then you would want to enhance those frequencies with an EQ and reject unwanted tones with your crossover network. It is all personal preference though. If you think it already sounds good then why mess with it.
    Jan 11, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
    My kicker zr240 cuts off and on at low volumes
    Double check your connections from the power wiring to the speaker wires, sounds like a short.
    Nov 03, 2009 | Kicker ZR240 Car Audio Amplifier
    My kicker zr240 powers up but its no sound coming out the amp the guts of the amp looks fine
    it could be your input section on your amplifier were you rca jacks go in but you should check and make sure it aint your cd player out put on your rca jacks the easy way to check this is with a meter and a cd playing in your cd player turn your meter on volts usually your out put on rca 2.5v some cd players put out 5v so take your postive tester needle and stick it in the inside part of your rca jack and take negative tester needle and touch the outerside of the rca jacks and see if you get any reading if do that good on that part but on your amp no it could be in the input section of your amp it could be as simple as a burnt trace wire on the bottom circuit board or a op amp chip theirs alot in a amplifier but you can test them with a meter to find out witch one bad but i would take it to some one that work on amplifiers if you dont know how to test them
    Oct 31, 2009 | Kicker ZR240 Car Audio Amplifier
    Kicker zr240 amp
    yup your problem is most likely the solder joints have vibrated loose. dont use it till you resolder all the solder joints on the mosfets and the bigger transistors on the board.
    Jan 06, 2009 | Clarion DXZ945MP CD Player
    Kicker amp shutting off
    hello my friend you should have the input signal set to 500 miliamps do not go over, another thing is that if you have good ground and the battery is good and it has the sufficient amps to push it.also the ohms of your spkrs are not too low,you need to check all that.
    good luck
    caypianan@yahoo.com
    Nov 02, 2008 | Kicker 04KX250.2 Car Audio Amplifier
    Kicker ZX500.1
    not getting enough air to cool off amp, if amp is in an inclosed area with restricted air flow, amp will over heat and shut down, once the amp has cooled off, it will reset.
    Mar 21, 2008 | Kicker KX400.1 Car Audio Amplifier
    Clarion DXZ945MP CD Player Logo
    201 people viewed this question
    Top Clarion Car Audio & Video Experts
    xxxxxx xxx
    Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
