Tub won't spin
During an attempted spin cycle, the tub made a loud intermittent banging noise while attempting to spin. It would make a short movement and that's all. It is NOT the coupler. I checked it. Is it the transmission? If so, does that mean it needs replacing? If so, assuming the cost of a new trans would be about $200 would I be better off just buying a new machine?
Thanks
    Problem Solver:
  • 7 Answers
On my machine which is a belt-drive. This simply mean the belt has worn off. The machine still wash, but hesitate to spin. With a help pushing it might spin, but not every time.
Posted on Jan 06, 2009
Airplane noise during spin cycle
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 14, 2015 | Washing Machines
Washing tub unbalanced
Apr 03, 2015 | Washing Machines
Why does my LG washing machine make a rattling noise even at low RPMs?
It is not uncommon for items that get loose in the washer (paper clips, coins, etc.) to slip underneath the "paddles" and then make noise as the drum turns. While an annoyance, it is not anything to be overly concerned about. Eventually the item(s) will come back out.
Mar 19, 2015 | LG WM-2277HW Front Load Washer
Could the spinning barrel be off center,what has come off?
By the way my advice is free cuz God is good!
Mar 19, 2015 | Washing Machines
Loud squeeling grinding noise
Oct 02, 2014 | Whirlpool Cabrio WTW8600YW 28" Top Load...
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Spin cycle is loud
Jul 01, 2014 | Whirlpool WTW5550X Washer
Thumping and banging during the high speed spin cycle
Feb 08, 2014 | Frigidaire Washing Machines
Washing Machines Logo
Top Washing Machines Experts
