Question about Clarion DXZ945MP CD Player
Kicker zr240 amp
When sitting still the amp works just fine. But when I start driving the amp will kick off and on. I left my back seat down so I could see the power light on the amp when it cuts off. The light stays on but the sound from the subs quits. I thought it was a lose ground wire but that would kill the power to the amp if that were the case. This happens as soon as I turn it on so its not an overheating issue. Could it possible be the crossover? Any help would be great.
  • aleianated May 07, 2009
    I HAVE THE SAME PROBLEM WITH MINE, I CAN REACH BACK AND KINDA WIGGLE THE CROSSOVER MODULE AND IT WOULD COME BACK ON. I'M CURRENTLY LOOKING FOR A REPLACEMENT MODULE. ANY SUGGESTIONS ON WHERE TO GET ONE?
    Problem Solver:
  • 16 Answers
Yup your problem is most likely the solder joints have vibrated loose. dont use it till you resolder all the solder joints on the mosfets and the bigger transistors on the board.
Posted on Feb 06, 2009
I doubt it is loose solder joints...im sure it is just a bad connction between that junk crossover and the even crappier amp. Try just cleaning the connection points with rubbing alcohol or something and see if that works...if not, try building up the flat male side of the connection with a tiny hint of solder and force it to connect...if that doesnt fix your problem...throw that POS away and buy a real amp!
Posted on Jun 04, 2009
Why does my amp turn off when i hook up my 12 inch kicker
Possibly due to a poor battery, you could try installing a power cap to prevent the amp shutting down/protect due to low voltage when the starter kicks in.
May 10, 2012 | Kicker 07CVT124 12 inch ShallowMount...
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
Zr240 kicker amplifier. how many watts is it
  • 60 watts x 2 at 4 ohms
  • 240 watts x 1 in bridged mode
  • 120 watts x 2 at 2 ohms
  • Dec 23, 2010 | Kicker Car Audio & Video
    77 fxe kicker slams back when started and the clutch is pulled in . replaced thrust bearing and the kicker gear stop was snapped off.. replaced and re assembled per shop manuel..?
    all kick starter kicks back when starting just give it a little keck like just push dawn on the kick starter to wear it just turnes over 1once than jump on it than it should fire without kicking back but kick it hard or it will kick back
    Dec 05, 2009 | Harley Davidson FXD Dyna Super Glide...
    My kicker zr240 cuts off and on at low volumes
    Double check your connections from the power wiring to the speaker wires, sounds like a short.
    Nov 03, 2009 | Kicker ZR240 Car Audio Amplifier
    My kicker zr240 powers up but its no sound coming out the amp the guts of the amp looks fine
    it could be your input section on your amplifier were you rca jacks go in but you should check and make sure it aint your cd player out put on your rca jacks the easy way to check this is with a meter and a cd playing in your cd player turn your meter on volts usually your out put on rca 2.5v some cd players put out 5v so take your postive tester needle and stick it in the inside part of your rca jack and take negative tester needle and touch the outerside of the rca jacks and see if you get any reading if do that good on that part but on your amp no it could be in the input section of your amp it could be as simple as a burnt trace wire on the bottom circuit board or a op amp chip theirs alot in a amplifier but you can test them with a meter to find out witch one bad but i would take it to some one that work on amplifiers if you dont know how to test them
    Oct 31, 2009 | Kicker ZR240 Car Audio Amplifier
    Amp goes into protection
    make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
    Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
    Subwoofers
    sell me the subs it would be better
    Oct 29, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
    Clarion DXZ945MP CD Player Logo
    236 people viewed this question
    Top Clarion Car Audio & Video Experts
    xxxxxx xxx
    Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
