Back to:
Tags:
Ricoh Aficio 450 Copier
We receive functional problem 326.....we cannot... (by 2 users)
posted by liera on May 27, 2007
we receive functional problem 326.....we cannot solve...pls help
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by mooody, posted on Jun 13, 2008
when i turn my machine on the sc 326 appears
Best Solution
posted on Jul 05, 2007
FixYa! (100)
Gunslinger
Rank:Master Master
Rating: 87%, 12 votes
Service code 326 means the laser unit is bad.
Could also be bad door switches on this model since they cut the voltage off to the laser if the door is opened. hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on we receive functional problem 326.....we cannot solve...pls help:
I don't want to Accept this solution
Solution #2
posted on Jun 07, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
to get into SP MODE Press Yellow 107 then hold down the red key. this will get you in but what you do when you in is up to you . as remember pressing the wrong thing could damage something else !!! good luck
Thank You!
Solution #3
posted on Jul 07, 2007
Not Rated (0)
NALDZ
Rank:Master Master
Rating: 76%, 13 votes
remove the LD unit and clean the mirror in a clean cloth with some drop alcohol
Thank You!
Solution #4
posted on May 27, 2007
Not Rated (0)
24 seven
Rank:Wiz Wiz
Rating: 82%, 1175 votes
call Ricoh and ask how to get machine in self-diagostic mode (there a keypad combinations to enter this-usually 2-3 keys pressed at once)
Thank You!
Can you Help with these Copiers problems?
Copiers
SIR, when i am using ADF to photocopy LGL size document...
Copiers
I have a Risograph RZ220 with the code d--13 --9. The...
Copiers
how to reset the copier thanks chris
Copiers
I have a copier that went a little bit over the 100k with...
Copiers
Everytime i try to make a master copy,it didn't makes a...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
