Hp IIp 55 error code and 79-09ae service Hi, Turning on HP IIP gives 05 Self Test, then 55 Error (blinking) with NO sound of turning rollers like usually happens. ALT CONTINUE does nothing ALT RESET gives 79-09ae SERVICE. Any ideas?
  • 125 Answers
Replace Fuser
Posted on Jan 07, 2009
  • Paul Douglas
    Paul Douglas Jan 10, 2009
    Hi jmadej:
    Ther is only one other problem that it will be and that is your main drive gear assemble. If you (first unplug the printer from power) open the back door and remove the fuser, look at the gears on your upper left to see if they are worn. These gears drive the fuser and main motor drive assembly and if they are worn they will not turn the fuser and you will get that 55 error.
  • Paul Douglas
    Also check main drive motor.
Where can I get an xp driver for the sjiip C1790a please
The HP Scanjet IIP scanners are supported in Windows XP and the drivers included on windows XP CD.
If you can’t manage download it from Windows XP operating system please try to update your Operating system then try again.
All the best.
Mar 27, 2010 | HP ScanJet IIp (C1790A)
My HP Laserjet IIP Plus is giving me an 'Error 41' message, but it will feed a test page. The problem is that the page is gray all over. You can dimly see the printing, but the printer is spreading toner...
I recommend that you should have to find a shop that specializes on printer in order to test your printer and to be able to see what us the problem in the printer and able to fix it after it finds the problem. In that way, you can avoid any further damage it may cost in your printer.
Aug 18, 2009 | HP LaserJet IIp plus Printer
HP Laserjet IIP Plus only prints solid black pages.
Best bet is to just get rid of this machine...machine is outdated and parts are few and far between.
Jun 04, 2009 | HP LaserJet IIp plus Printer
the face down assembly needs to be replaced.
the rollers have lost their spongeness and causes the fan-shape jam.
it will need to be replaced..
the part # is RG1-1791-070CN
thank you
May 20, 2009 | HP LaserJet IIp plus Printer
Error 50.6 in hp laserjet 9500hdn
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Jan 22, 2009 | Office Equipment & Supplies
HP LJ II P plus
The laser PCA is bad.
I removed it and the printer functioned.
I thank you really after all.
Jul 25, 2008 | HP LaserJet IIp plus Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
Error 41 on Brother MFC-3420C. I have tried unplugging and restarting. There aren't any paper jams or visible problems. There is dial tone to machine but fax will only ring when called, no start tone...
Hi,have the same problem since yesterday. Look on """You can fix the ERROR 41. Go to and look up part# LK0935001. They sell it for $39.99 and it is very simple to install""".Good luck.
Apr 13, 2007 | Brother MFC 3420C All-In-One InkJet...
370 people viewed this question
