Question about Lexmark Optra E312L Laser Printer
The E312 is printing pages in all black. I've replaced the cartridge and cleaned it. What do I need to do to get it to stop printing all black/vey dark?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
I've a 564XL black cartridge when inserted into a HP Photosmart 7525 refuses to print...it happened while trying to print TICKETS WORTH $261 for an event this Sunday, the 25th...HELP......ROBE
The expiration date should not be of any problem. When the printer has an issue with the cartridge, it could be the contacts in the printer or on the print head are not clean or shiny. It looks as a communication problem. When the printer does not give an error, you just won't get black the hear must be cleaned.
OR when cleaning does not help we need a hefty measure.
When the print head is not on the cartridge, and cleaning does not work, remove the cartridge and let a drop of cleaning fluid fall in the nozzle, where the ink should go in. place the cartridge back and let the printer print a few pages of black. (just some text pages with black bold type face would do. Let it print till you see the printer is starting to show text, Then again do a clean cartridge and the printer should be fine for a while.
Jan 23, 2015 | HP PhotoSmart Office Equipment & Supplies
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
I,ve just replaced my black ink cartridge today,it printed good for a little while but now it barley prints black
Your cartridge nozzle may need to be cleaned. You can use the Lexmark Solution Center to clean the nozzles from dirts and clogs. You may refer to this article: How to Unblock (Clean) the Cartridge Nozzles.
Apr 10, 2011 | Lexmark X1150 All-In-One InkJet Printer
My pro905 stopped printing in black although cartridge is showing 50% full. what could be the problem?
Make sure you are using genuine Lexmark cartridges. It could be that your black cartridge needs cleaning. Try to do the Deep Clean Printhead function on the printer. Press Ink Levels -> press More Options -> select Deep Clean Printhead. The printer will then print a clean cartridge nozzles page. If black ink is not printed on the page, you may need to update your printer's firmware. The update corrects print quality issues on your printer. You can easily download and install the update using this link Lexmark Platinum Pro905 Firmware Update. Download and install the Pro905 update. Thanks.
Jan 04, 2011 | Lexmark Platinum Pro905 multifunction...
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing black line when coping
You may need to replace the toner cartridge or the fuser assembly.
If you open the toner cartridge door and see a black line on the roller, you will need to replace the cartridge.
Aug 07, 2009 | HP LaserJet 3050 All-In-One Printer
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Lexmark Optra E312L Laser Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
