Question about Symbol MC9090-G RFID Handheld Barcode Scanner
Cannot read symbologie/BarCode: i25(interleaved 2 of 5) from an MC9090-G running VT100 emulation. How do I configure the scanner within Telnet-CE/Wavelink?? Thanks. Dante Barboza
  • Anonymous Apr 30, 2009
    i have the same problem!! what i did is i'd downloaded datawedge form symbol.com and place the file to application using active sync then install the file to MC9090 device, not sure what symbologie the airline baggage tag is??? but it works, the only thing is once i remove the battery for being low i lose all the configurations such a profile, wireless Key ETC ETC.... any suggestion?
    thanks
    Ray ( LAX airport )
  • 97 Answers
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
Posted on Mar 26, 2009
    Novelist:
  • 75 Answers
In addition to thesupperdude's solution.
The MC9090-G comes with a licence of Wavelink TE pre-installed.
I would just download the latest version of Wavelink from the site that supported this version:-
v7.0.82
And then update the gun. This is done very easily using the Wavelink application (Install App button) and following any prompts.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 11, 2009
MC9060 WON'T READ CERTAIN BARCODES
The application, can be configured to read the barcode. There is an application on the scanner it will tell you what the barcode actually is. either Scanwedge or Scan both should be in the Sample applications, or from the desktop click on "Olt"
Aug 20, 2013 | Symbol MC9090-G RFID Handheld Barcode...
Function keys on MC9090
hi,
Sound like you need to look at your Keyboard mapping files, easiest way to fix this is to use Motorola System Configuration Manager - Downloadable from the Motorola website.
If the unit need to be restored to factory defaults, than a fast way is to run the Clean boot files from the SD Card also downloadable via the Motorola site - search for 'MC9090 Clean boot'
Mar 04, 2013 | Symbol MC9090-G Barcode Scanner
How to configure Function keys on MC9090 from ITS service
my problem is in the configuration of symbol MC9090 in comunication with sap when send function Key ( F5) .
Question .
What the value that the SAP waiting this process?
May 17, 2010 | Symbol MC9090-G RFID Handheld Barcode...
We are running Wavelink or Avalanche software on the MC9090. Unfortunately, the top and bottom of the screen is being used seemingly by the Options and Wavelink toolbars, respectively. This reduces the...
The setting to hide the options menu and start bar can be done within the Emulation Parameters on a host PC.
From the main switch board run "Emulation Parameters" and then expand >>Emulation>>Display
This will give you a wide range of options which are useful to you:-
  • Hide Horizontal Scroll Bar
  • Hide Menu
  • Hide Vertical Scroll Bar
  • Start Menu
I would then set a key within:-
Menu Toggle Key
So that you could bring it up at any time when required. Most people use <CTRL><M> which is in fact <C><0x4D> (from memory).
Hope this helps.
or TEL +44(0)1202 620955
May 05, 2010 | Symbol MC9090 Barcode Scanner
MC9090 being used outside in sunny conditions
If you are using Wavelink TE you can set the screen to different colours. That may help.
or TEL 01202 620955
Sep 29, 2009 | Symbol MC9090 Barcode Scanner
I need to map the F5 on an MC9090
You need to contact the Wavelink Help Desk...http://www.wavelink.com/support.aspx
They can walk you through it.
Cheers..
Billy Barcode
Aug 05, 2009 | Symbol LS2208 Handheld
Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Jan 08, 2009 | Symbol MC9090 Barcode Scanner
Mc9090-g
It's not like your old DOS scan guns where there was a definite number of characters (rows and columns) that could fit on the screen. Instead, it runs Windows Mobile or Windows CE, which has a graphical interface (like your PC). It comes preloaded with terminal software from Wavelink to connect to your AS400, and you can set how large or small you want the font to be in that terminal emulator. So the answer is, the "lines per screen" and "characters per line" can pretty much be as many or as few as you want. It's a trade-off between how much you can fit on the screen and how well you can read it if you were to choose a font size that is too small.
I will say that Wavelink does a good job with this emulator at allowing you to scroll around the screen though. If there is anything that won't fit on the screen, you can just press the Ctrl key and then use the up/down/left/right arrows to page around the screen.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk for the MC9090)
www.radicomm.com
Mar 25, 2008 | Symbol MC9090-G RFID Handheld Barcode...
Symbol MC9090-G RFID Handheld Barcode Scanner Logo
2,160 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
