Question about Garden
No power to fuel shutdown solenoid when cranking or key on
Tractor was running great, plowing snow, when it just died out. Crank/no start. Checked power to solenoid,nothing. Ran a temporary hot wire to the white wire of solenoid and, with wife cranking it over, I touched power to red wire and she fired right up. Got it back to the shed. I have no schematic, but I'm thinking its a safety switch?
  • tugsdad Jan 29, 2009
    Sorry I didn't respond sooner. Went away for a while, Just returned home. I'had already checked fuel system and electrical as far as i could. While tracing wiring, I have come to the conclusion that the glow plug relay also plays a role in power to the fuel solenoid. I have ordered a new relay. Will post my results.
  • 37 Answers
SOURCE: Craftsman tractor will not crank over.
Hi, has your problem been solve yet? please respond
Posted on Nov 23, 2008
SOURCE: Trouble starting Craftsman Lawn Tractor Mod# 917-272350
It is time to rebuild your carburetor paying special attention to the float and seat.
Gasket set is about $30 delivered and gallon can of gunk carb cleaner with a parts basket is $21 at kragen auto parts. takes about two to three hours. Or you can but a new carb for about $150.
Posted on Jan 29, 2009
  • 376 Answers
SOURCE: 14 hp dynamark tractor that won't start
Have you checked the inline fuse?. Also you could unplug the ignition switch and clean the terminals, particuarly the one with red wire in it. That the one that has constant power to it and tends to corrode over time. Hope that helps.
Posted on May 23, 2009
SOURCE: mtd 10.5Hp will not crank 36 inch cut
blown fuse by solenoid
Posted on Jun 06, 2009
  • 313 Answers
SOURCE: john deere 42 inch,17.5 hp-was running good then
have you had a look at carb side of things as it may be having fuel starvation probs.. the fuel in line not getting through jets or float chamber cleanly.. also the tank might have contamination from rust or debris..
Posted on Aug 13, 2009
My for f250 heavy duty will crank but wont start. what cold be the problem?
thats a tough truck
start with a a fuel delivery problem
if diesel glow plugs
if petrol check spark at the plugs
its a timing chain motor doubt if it broke a chain or skipped a tooth
Apr 01, 2017 | Cars & Trucks
Tractor will not crank over.Why?
Sounds like your battery cables on the starter is not working and needs replacing. i had a loose cable and would not work.Your solenoid may be bad as well.
Nov 07, 2015 | Garden
After 45 minutes of run time drops to half power
it is droping to half power to stop the motor from over heating check the water level and oil top them up.
Jun 27, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Yard man riding mower
By crossing the terminals on the solinoid you have taken this component out of the picture, so the problems has to be in the engine or the starter, if the auto deco valve in the engine is not working the engine will be sluggish to crank over.
Sep 28, 2013 | Mtd Garden
96 Monte carlo z34 won't crank over unless I jump
Sounds like a problem with the key switch, probably the security system. You may only have power to the fuel pump when the engine is cranking.
Is the security light on or flashing ?
Jun 29, 2013 | Cars & Trucks
No engine cranck, no warning lights
Check solenoid on starter motor.
A quick fix which works on occasion when solenoid hasn't completely failed is to strike the starter motor body with a hammer whilst trying to start.
Check power to solenoid with the key turned to crank position.
No power to solenoid? Check steering lock cluster, relay and fuses.
Do you have a flashing key on the instrument cluster? Change or re-program the ignition key
If you have no warning lights, no power to solenoid then check negative terminal fixing from battery.
If all is well, yet no crank, then replace starter motor and solenoid.
Oct 29, 2012 | 2005 Dodge Grand Caravan
My truck sat up for probably 3 or 4 years cranked and run fine yesterday but today it wont crank at all any ideas?
If it won't crank over, it's not a fuel issue, but a starting circuit issue. The gas may be stale, but if tank was full all that time, I don't think that would be a problem.
Pull off the small wire on the starter solenoid, and see if it has power when key is held in crank position. If power there, the starter or solenoid or the battery connections from battery to starter need to be checked or tested. If no power to solenoid when key is in cranking position, the ignition switch may be bad or the neutral safety switch (or the clutch start switch if a manual) or the starter relay needs to be checked.
If you get it cranking, and still no start, look down the throttle body bore and watch your injector spray pattern while the engine is cranking-you should see a fine, cone spray pattern coming from the bottom of the injector. If it just drips and no cone pattern, or no gas coming out, injectors need cleaning (probably from stale gas). Good luck.
Oct 23, 2012 | Cars & Trucks
Won't Crank Over with key, unknown if it will start
To start the tractor, current flows from the battery through the "start" contact of the ignition/start switch, then through two safety switches: one is activated by having the brake on (or by having the mower in neutral). The other is part of the PTO (engage mower blades) switch. I don't know which would come first on your mower, so get a test light or a multimeter and trace your way along this path. The current then goes to the small terminal on the solenoid.
Another possibility -- in changing the motor, did someone leave a ground lug off, or worse, maybe they just cut it off when removing the old engine? That would also prevent things from working. Good luck! If this is helpful, please rate it, thanks!
Jun 06, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Will not crank or start. i can jumper cable to
When you are jumping it off from the solenoid, there is no power going to the fuel shutoff solenoid under the carb if your battery is dead. If you can't hear the click from the fuel solenoid when you very first turn the key to on, it's not giong to start by jumping other than through the battery.
Jul 01, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
157 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
