Question about GoVideo Televison & Video
VCR Deck not working
When inserting a cassette into the VCR Deck it will not 'grab' the VHS tape to take it into the machine.
I have the DVD Recorder+VCR GoVideo Model VR3930; purchased 4 1/2 years ago. Is this worth taking to be repaired (or better yet, can I repair it myself?).
I found a website that explained what was wrong and how to fix.
Posted on Jan 07, 2009
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When I play mini dv it says insert head cleaning cassette should i insert one, what brand do you recommend?
that is a sony thing....you must insert and run the cleaning tape for 10 seconds before any other feature will work...no cleaning tape, no operation of the device. my deck and sony cameras all do the same thing.
Oct 22, 2009 | JVC SR-VS20 Mini DV/S-VHS VCR
Vhs tape won't load completely
I assume the cassette flap lifts fully, allowing the tape to go into the deck as this is a small lever mechanism. When the tape goes so far in, it activates a switch to start the loading motor this is usually a metal or plastic pin on the deck depending on the make of VCR (as you do not mention the model of your VCR, I can only give you an overall explination of a carriage mechanism). The pins at the side can incorporate a start sequence as well & will guide the deck into position. It looks like your machine has gone out of alignment & to solve the problem you would need to remove the cassette housing & re-align the pin at the side so that it follows the correct path, this can sometimes be a tricky & awkward thing to do as you can break parts of the deck if it is not aligned correctly. My advice would be to take it to a service repair centre.
Jul 21, 2009 | Televison & Video
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
VCR
Hi dennis176,
Unfortunately, I am not aware of this kind of setup. This kind of solution would not be very efficient. For this to work there would need to be an insert to the VCR (similar to that which is used in a cassette player to convert CD audio) attached to a DVD player. Because you would require a device to play the DVD and send the video/audio to the insert (if it existed) it would actually be more efficient to simply connect the DVD player to the television. The reason inserts exist for cassette players is primarily that it prevents replacement of an entire car stereo system. This is not the case with a VCR. You may consider purchasing a DVD/VCR combo if you wish to maintain the ability to play VHS tapes. If you own a TV/VCR combo, your least expensive option would likely be to purchase a separate DVD player.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Emerson EWV603 VHS VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Can't insert tape into deck
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Sep 27, 2007 | JVC SR-V10U S-VHS VCR
Televison & Video Logo
118 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
