Question about Whirlpool Refrigerators
Warm water out of water dispenser
Water is not cold coming out of water dispenser on front of whirlpool refrigerator.
  • jccarmean Jan 06, 2009
    Not a new refrig. Refrig is a 1999 model. Temp is luke warm. Not chilled like it should be. Ice is still making.
  • 594 Answers
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot.
IF it is on the hot the fridge is cooling it down to warm.
Please let me know if this helps you.
Posted on Jan 06, 2009
Whirlpool refrigerator WSF26C2EXF01 water dispenser not working
This sounds like the water inlet valve has gone bad.. First before u replace it check to see that you have water coming to back of fridge as it could be restricted causing no water to reach the fridge.
Apr 04, 2014 | Whirlpool Refrigerators
Water won't stop coming out from the cold water dispenser
The cold water dispensing valve can be stuck or defective. Sometimes jiggling the valve can make it stop running
Sep 30, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The water in the water dispenser is not coming out cold, it is warm water
This may be a little too obvious of an answer, but have you checked to make sure the supply line under the sink is connected to the cold line, and not the warm line?
Apr 15, 2011 | Kenmore Side by Side Refrigerator
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water coming from new refrigerator water dispenser is not cold
CHECK TO SEE IF THE DRAIN LINE IS CONNECTED TO THE PAN BEHIND THE KICK PLATE. I would offer a diagram but I'm in search for one myself.
Jun 16, 2009 | Refrigerators
No water on dispenser Model#ED5CHQXKQ01
most likely you have a frozen water line to the dispenser. it could be inside the back of the refr section that is just too cold or inside the freezer door.
either one can be tested by allowing each to warm up for 15 to 20 minutes and see if you get water thru door.
do you hear a buzz from the water valve coil when you push the dispenser lever? if so then the water line is probably frozen somewhere.
Jan 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool water dispenser
IS THE FRIDGE OMPARTMENT COLD ENOUGH AS THE TANK THAT HOLDS THE WATER IS LOCATED IN THE FRIDGE COMPARTMENT.PLEASE FEEL FREE TO ASK MORE ADVICE.MOHAMED
Jul 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
657 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
