Question about Muratec Copier
Memory overflow I have a MFX 1430 - the toner has been out for a few days...I do not want to print the stored faxes how do I delete them?
  • 77 Answers
Maybe if you have the owner's manual...try consulting that or...
Try this: http://www.muratec.com/downloads/manuals/F-520_560_MFX-1430_2030Users_Guide_Ver.3.pdf
Posted on Jan 06, 2009
DHCP server did not repond
Mat be your dhcp server is not up.please enter a static ip which is not in range of your dhcp server.
Oct 08, 2014 | Muratec Mfx - 1430 Fax, Copier, Scanner &...
Papers that are faxed over are automatically going into memory......how do I get it out of memory mode and get my faxes?
Pages recieved go into memory if there is a problem...for example, no paper, no toner, some kind of "error" code or alarm on the machine....if you are unsure..switch the machine into the copy mode and make a copy and see if the page prints out ok., if it does then there is no reason for the pages not to print out when received. See if the display is saying anything odd.
Nov 03, 2010 | Muratec MFX-1430 Copier
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
Muratec MFX 1430 Fax / Printer / fax does nto turn on.
UNFORTUNATELY YOU MAY HAVE LOST A PCB. IF THERE IS NO DISPLAY AT ALL YOU WILL PROBABLY NEED A SERVICEMAN. WOULD STRONGLY SUGGEST YOU GET EQUIPEMENT LIKE THIS ON A "SURGE-PROTECTOR". ITS A LOT EASIER TO REPLACE A $25 SURGE PROTECTOR THAT POSSIBLY HUNDREDS FOR A NEW PCB.
Jul 08, 2010 | Muratec Copier
Muratec MFX- 1430 Printer
first of all, you can change the toner cartridge at any time. the roller below is probably the transfer roller, which can be cleaned. you may also want to consider that the drum cartridge could be the culprit.
since this is a multi function machine, make sure that the lines are not showing up when you print, or receive a fax. if the lines ONLY show when you copy, then clean the small **** glass under the document feeder, that should be the source.
Apr 01, 2009 | Muratec MFX-1430 Copier
Muratec mfx-2500
Try unplugging the power cord for 10 seconds, but you might need a technician to access the SERVICE MODE.
Oct 22, 2008 | Muratec MFX-2500 Plain Paper Laser Fax
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Muratec Copier Logo
423 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
