Question about ASUS P4SGX-MX Motherboard
Display problem few days back i purchased a xfx 8600 gt card 512 MB. when i installed it and connected my monitor cable to it, and switched on the pc, there was no display on the monitor, although i could hear windows logon sound. i have asus P5GZ-MX motherboard with integrated graphics media accelerator.plz help. its urgent
  • 728 Answers
Hi nasir_nit,
It sounds like you need to update your BIOS on that board. HERE. Make sure you pick the correct operating system. Once you update your board you should be ok.
Good Luck!
Mark
Posted on Jan 06, 2009
  • ASUS Master
  • 4,806 Answers
Hi there
try going into the bios settings and disable the on board graphics and change it to PCI or PCI Express.
You may have to plug the monitor into the on-board VGA port to do this, once done shut the computer down and change graphics port, then restart the pc, your problem should now be solved
Good luck and kind regards
Ihave nvidia 8500 gt 512 mb,ddr2 gc.I use it for 2 yrs.Even it has now within 1 yr. warranty period.i play fifa on pc.but a few days ago during playing game suddenly my display got black screen .when i use...
first, update graphics card drivers.
Check the radiator cooling, it is possible in the dust and graphics card is overheating.
But if the problem only with this game.
Try to search patches for the game.
Sep 21, 2010 | XFX NVIDIA GeForce 8500 Graphic Card
My graphics card is xfx 8600 gts my card problem is when i start my pc the display logo of my m/b is crash color and red boxes on the screen then my pc restart when system reach windows. So please help me
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
May 14, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
My graphics card is xfx 8600 gts my card problem is when i start my pc the display logo of my m/b is crash color and red boxes on the screen then my pc restart when system reach windows. so please help me
well my experiance with that card having a similar issue. i tried switch cables resetting the monitor to factory settings reinstalled drivers removed the card reinserted it. called xfx and it ended up being bad they rma it and got my new one and it worked fine then. hope this helps
Mar 24, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
Graphic card stopped working normally
Uninstall the current display drivers from the Control Panel > Remove Programs.
Then, go to Windows Update to download their version of the driver. It will work.
Aug 06, 2009 | Pine Technology XFX GeForce 9400 GT, PCI...
Dualview display disappeared
just disconnect tv connection and plugin the monitor connector the display should come automatically.
then go to nvidia control panel and connect tv and then configure the dual display.
then both will again work again.
Apr 18, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Screen not starting after installing graphics card
Hi rohit1987,
The XFX NVIDIA GeForce 8600 GT 256MB DDR3 PCI Express card uses two DVI ports on the back of the card. Display is most likely coming from the second port. Try moving your monitor cable to the next DVI port. You can do this while your system is running.
If you still do not receive display, post that here & we'll go over some other possibilities.
Good luck rohit1987!
Thank you for using fixya.
Mike
Jan 13, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
"Device will not start"
Does your mobo has a built-in graphics card? try disabling that onnthe bios.
May 13, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
My colors are like a raibow!(2)
Once a picture tube gets magnetized it may display the same rainbow effect on another PC. Do you have anything close to it that could be causing a magnetic field, like large speakers? If so move them farther away. A rainbow effect is definately a degaussing and/or a magnetic field interferrence problem. If the degauss circuit is functioning properly leaving it turned off for a few hours (so it cools to room temp internally) and then turning it on should make it degauss. It is possible that the degauss is not powerful enough to rid the tube of severe magnetism, in which case you need to use a manual (handheld) degausser.
Mar 09, 2008 | Pine Technology XFX® GeForce® 7950 GT,...
My colours is like a rainbow!!
I think the monitor needs a degauss.
mostly it will do the job
it happens because of magnetic reaction on monitors..
or the color sensor is gone....
Mar 09, 2008 | Pine Technology XFX GeForce 7950GT, (512...
ASUS P4SGX-MX Motherboard Logo
101 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
