Question about Brother HL-2040 Laser Printer
The printer doesnt want to take new ink first it said the drum and now it says the toner went to office depot and got new ink wont work
    Champion:
  • 320 Answers
Did you get brother oem toner or generic toner?
Posted on Jan 13, 2009
Always asking replace toner
my wife and I have a hp printer and I was purchasing ink cartridges from off ebay and I was getting that same thing all the time, even with new ink. I suspected since they refill the ink from empty ones that something was haywire. so I started buying brand new ones from like walmart or office depot and don't have that problem anymore. hope it helps!
Sep 02, 2015 | Office Equipment & Supplies
I have a hl2040 laser printer and i have black verticle lines on the paper. i have cleened the corona wire by sliding the tab back and forth on trum cartridge. the toner cartridge is new. the printer was...
Remove the drum and toner from printer, turn printer off and find the glass scanner bar on the top of the inside of printer. Clean that with a paper towel and window cleaner. Wipe dry. DO NOT SPRAY INSIDE THE PRINTER. Only spray window cleaner on towel.
May 26, 2017 | Brother HL-2040 Laser Printer
Epson 1400 not recognizing an epson ink cartridge
not necessarily faulty cartridge - had same problem went thru various cartridges some worked some didn't - in fact they weren't epson - so bought epson from office depot and that would not work, so not an issue of ink dried up - if yr printer is fairly old may be easier just to replace rather than waste time and money on trying to figure out problem
Sep 13, 2013 | Epson Stylus Office Equipment & Supplies
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
My LaserJet 1020 is printing a faint after image. Any suggestions?
take out and shake the toner Cartridge and put it back
Dec 16, 2009 | HP LaserJet 1020 Printer
The printed pages have a black lines that block out words or images printed under the black lines. I am using a friends Brother HL-5270 lazor printer, she has lost the manual. Six months ago, I took the...
The inside could be dirty, blowing it out could help, but first try taking out the toner and drum and cleaning the corona by running the blue tab near the front back and forth about 20 times and then blow out that area with a can of air. If you can see the lines on the drum, you may need a new drum.
Sep 17, 2009 | Brother HL-5270DN Laser Printer
Display an error OUt of Drum
The drum unit in your printer needs to be replaced. The drum is the pars that the toner fits into. You can take your old drum into Office Depot and they can get the right number for you if you can't find it printed on the top of the drum. The drum has a page print life and when the page count hits that number you have to replace it to continue printing.
I hope this helps,
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | Brother MFC 7420 All-In-One Laser Printer
Will not print at all
are you using generic toner or brother toner?????
Jan 05, 2009 | Brother HL-2040 Laser Printer
J1 Error, Changed a brand new factory-sealed toner, still getting J1 Error
Make sure you have the right code: J1 or J2.
one is for the drum and the other is for the ink.
Make sure the toner unit is for this model and not for a different model.
If the old modual is still available, check the connectors at the back and see if they are the same.
If anything else Call Xerox for repair. If the cartridge was bought through Xerox have your reciete available for warrenty.
If repairs still need to be made, A Xerox service call may be needed in order to fully repair the copier and warrenty the cartridge.
Nov 06, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Brother 1440 Printer Black streak - is it Drum or Toner?
perform a halfway test by printing something with a full page of letters or graphics and try and stop the printer before the print actually gets to the fuser but has the toner on it from the toner cartridge, remove carefully as the toner won't be melted into the paper and see if the defect is showing up on there. If it is then its your toner and if not then it's your fuser...hope this helps please leave feedback...
May 27, 2008 | Brother Office Equipment & Supplies
Brother HL-2040 Laser Printer Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
