Question about Sony MHC-RV888D Shelf System
Sony MHC-RV888D - TAPE Recording to Laptop as mp3
Hi, I am using Sony MHC-RV888D. I need to record the TAPE to my laptop as mp3. I have all the right softwares in laptop to capture sound coming in. I am connecting VIDEO/SAT OUT L/R jacks (red and white colour) to my laptop's microphone jack. when I play the TAPE, the tape plays as I hear it in the speakers and some mp3 file seems to be generated but when I play that file on laptop then no sound. Am I making some wrong connections? This problem seems to have eaten my brain....Someone please help me in completing this function. What are the other options to convert TAPE into MP3 using this music system? Thanks
  • 883 Answers
On laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
Posted on May 27, 2007
My recording has just disappeared after looking with zero size.
If you can listen to the recording, on the player, it must be a different format. Play the recording back whilst recording on your laptop, if your laptop has no internal microphone, buy an external one, for recording.
Dec 03, 2013 | Creative Labs ZEN Neeon 2 MP3 Player
Sony mhc-rv888d standby light is flashing
Output ic stk403-120 changed but still same problem.
Jan 04, 2013 | Sony MHC-RV888D Shelf System
How to burn a Cd
The Sony MHC-BX2 can record from a CD to a cassette tape. This model doesn't have a CD burner. The manual for the MHC-BX2 is available from Sony support: http://esupport.sony.com/US/p/model-home.pl?mdl=MHCBX2&template_id=1&region_id=1&tab=manuals#/manualsTab . See page 12 of the PDF.
If your unit is a different model, please post a comment with that model number. I wish that I had better news for you.
(on those shelf systems that can burn a CD, place a blank CD-R or CD-RW (if supported) in the disc tray. Use the function button to set the recording source (Phono with the Croseley units). Place the tape to record in the tape deck and press play reach a point a bit before the desired point to start the recording. (Some also will record from the radio, turntable, or other device. Again start the source playing.) Then press CD Record. Press Stop when you want the recording to stop or when one side of the tape/LP is finished. (Some have a Split Track button if you want to identify every track. Press this during the silent period between songs.) Otherwise, you will get one track per side with tapes/LPs.)
Jul 10, 2012 | Sony Audio Players & Recorders
I CANT RECORD CASSETTES ONTO A FLASH DRIVE
You can't. Cassettes are analog and the USB only recognizes MP3. The USB will only record off a normal CD or a CD with MP3s on it. It won't record other formats. The unit only allows to record from CD to cassette or from CD to USB. There are some cassette decks that will convert to MP3. Just do a search for "cassette to MP3 converter"
Apr 20, 2011 | Sony LBT-ZUX9 Shelf System
Can i get a product manual of rv999d?
Are you looking for Instruction Manual copy of MHC-RV999D ?
Let me know to upload it so can download from given link.
Thanks.
Mar 27, 2011 | Sony MHC-RV888D Shelf System
Getting a NO TAB when trying to record a tape from another tape.
I would check out the switch that detects the recording tab in the machine. It might have become bent out of shape so it stays open even when a tape presses against it.
Mar 19, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Dubbling cassette tapes
After looking @ the owner's manual online, I can see why you're confused. Man! It shouldn't that tough. You can always tell when the Chinese translate anything into English. If look you closely enough on pages 18 & 19, whenever the directions refer to "manual recording" one of functions that they don't specify is the recording of 1 tape onto another. The way that this manual was written the writer apparently didn't envision that anyone would want to do tape-to-tape (dubbing) recording.
On pg 18 it says to load a recordable (blank) tape into the B side deck. Easy enough. Next comes the tough to discern part.
In section 2 where it mentions "For Manual Recording and Sound Mixing:" Select the desired source to record or mix. In your case that would be the A deck. Here is where they needed to take a little time and explain that tape-to-tape recording is one of those possibilities. Notice that you'll need to place the B deck in standby. Then select the REC PAUSE/START to start the B deck & then (this is another place where they needed to be more clear) you'll need to simultaneously start (press the play button) the A deck which would be the recording source. In the future just remember that the A deck is the source and the B deck is the destination.
Good luck.
Mar 05, 2008 | Sony MHC-GX470 Shelf System
Sony MHC-RV888D Tape Recording to LAPTOP - How to connect?
you have to connect the S-VIDEO output of the device to your laptop via s-video - usb cable , if they do not have a cable like that than you might as well use an adapter from s-video to usb, if u have your hands on one.
the second method is to hook up a audio recorder from the speaker output, and use a volume controller witch steps down the speaker output so you can plug the cable directly to your laptop microfone output..
good luck!
Apr 11, 2017 | Sony MHC-RV888D Shelf System
Sony MHC-RV888D Shelf System Logo
185 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
