Question about Lexmark X5470 All-In-One InkJet Printer
Documents stack up but don't print
Seems to be stuck in "Copy" mode. HELP, please!
    President:
  • 8,637 Answers
First check to make sure your printer is set to DEFAULT.
If it is then try
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
How do I clear the memory
I would think that the document is not on the printer, it's in the printer spool. Open the printer properties and clear the queue.
Mar 13, 2015 | Office Equipment & Supplies
Our printer seems to be 'stuck' in copy mode and will not print documents
Could be a software issue. Try to uninstall and reinstall the printer driver.
Dec 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer will not copy although we can still print documents sent from the computer.
Is it infax mode?
Do you get a green Start Button?
Are there any error codes diaplayed when you push the button?
If no to these, unplug the machine for several minutes and restart.
Hope this is of some help
May 19, 2009 | Sharp Office Equipment & Supplies
Will print but not copy or scan
sir,
click this link to solve your problem
thanks
good luck
Nov 26, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer will not print document coming from PC
On your WINDOWS desktop, left click the START button. LEFT click on CONTROL PANEL, then left click on PRINTERS. On the PRINTERS screen, check for an icon of your Canon printer. If it is there, right click on it, and from the drop-down menu, left click PROPERTIES. On the PROPERTIES page, check if SET AS DEFAULT is checked. If it is your default printer, left click on the PRINT TEST PAGE button and see if it prints. If not, try following the onscreen instructions to correct the problem. If your Canon printers icon does NOT qppear on the PRINTERS page, the driver is not there, Go to www.usa.canon.com ,and left click on the DOWNLOADS tab. Follow the onscreen instructions and download and install the driver. You may have to do this on both computers, or set up one computer to SHARE the Canon with the other. Follow the INSTALL WIZARD'S instrictions, and you should then be able to print again.
Jul 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
X6150 Copy problems
Had exactly the same problem. Solved by turning copier on, then unplugging it for 30 seconds..plug back in...Problem solved.
Mar 21, 2008 | Lexmark X6150 All-In-One InkJet Printer
Brother mfc 420 cn does not print red color
do you use generic ink? If yes, the generic ink might have clogged the ph (valve stucks inside because of lack of additives!).
Anyway, do this:
(use near full level ink carts!)
make sure carts are placed well and are secured.
Press menue then start bk copy then fortimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy. ,achine runs a power purge. when fisihed press 9 then 9 to leave the mode. press ink etc. to run a quality test print.
If you still cant see any magenta, the ph is defective and needs replacing!
Dec 19, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
