Copy off set
Copy comes out as if I put original off to one side but original is on glass correctly
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
What tray are you making copies out of? Does it happen ( the off setting) from every tray and the bypass tray ( if you have one)? If the copies are offset from only one tray, check the paper guide alignment for the tray ( paper side and end guides in the tray). Check to make sure that the machine see the proper paper size. If you are having the offset problem from all the trays then you are looking at a registration problem and woould need to replace the reg> clutch/ motor.
Posted on Jan 07, 2009
  • cactusman252 Jun 09, 2011
    For me it was the tray, i opened it up and the papers were not aligned, after straightening them up i moved the notch to Letter and it fix the problem.
    THANKS A LOT......i spent 2 hours looking into the configurations....
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Tip
Troubleshooting MINOLTA DI 1611, DI 2011
The copy is too light. The copy density is set too
light.
Use the Auto/Photo
key to select a darker
copy density .
The copy paper is damp. Replace the paper.
The copy is too dark. The copy density is set too
dark.
Use the Auto/Photo
key to select a lighter
copy density .
The document was not
pressed close enough
against the Original Glass.
Position the document so
that it is pressed closely
The copy is blurry. The copy paper is damp. Replace the paper.
There are streaks through the
copy.
There are specks throughout
the entire copy.
The Original Glass is dirty. Wipe the glass with a soft
dry cloth.
The document pad is dirty. Clean the document pad
with a soft cloth dampened
with a mild detergent.
The original is highly
translucent, such as diazo
photosensitive paper or
OHP transparencies.
Place a blank sheet of
paper over the document.
A double-sided document is
being copied.
If a thin double-sided
document is being copied,
the information on the back
side may be reproduced in
the copy. Use the Auto/
Photo key to select a
lighter density for the
background.
The Imaging Unit has
reached the end of its
service life.
Contact your service
representative.
on Dec 18, 2009 | Office Equipment & Supplies
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
When making two sided copy, a messae is given like "Remove doc. on glass"
please be specific, did you put original in dadf ( auto feeder ) or on copy glass?
Aug 06, 2010 | Canon iR 2020i Laser Printer
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Sir i face problem in di 650,i place original
Sir,
Do you have the paper selection in AUTO? Mite you also check your defaults settings
Feb 20, 2010 | Minolta Office Equipment & Supplies
Scanner will not initialize properly, can make
If the scanner is not positioned correctly ,indiferent to make a copy to use the ADF or make to the original glass the copy problems is identical.Clean the scanner glass,original glass and the white level band,the erase lamp and check the OPC drum.If the problem persist need to perform the FD and CD adjust for the paper tray.Make someone copies use the A4R tray,and A3,and see the different.
Please answer to help you.You need the position correctly the problem source.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Image classD661 blank copy
If you just changed the toner cartridge, you probably forgot to remove the metal foil seal, from the side of the new toner cartridge.
Dec 07, 2007 | Canon imageCLASS D661 Digital Printer
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
48 people viewed this question
k24674
