Question about Olympus SP-570UZ Digital Camera
Problem with my Olympus SP-570UZ- zoom error
When I turn on the camera in any shooting mode lens extends part way, you hear a whirring sound then see zoom error on the screen, then it retracts.
  • Anonymous Jan 11, 2009
    I have this same problem.
    I have a slightly different camera, but the problem is exactly the same =/
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Olympus 570UZ. when I turn on it display error de zoom and then it turn off. Luis
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Aug 22, 2010 | Olympus SP-570UZ Digital Camera
What size uv filter do i need for an olympus sp-570uz camera ?
The SP-570UZ does not have a filter thread; therefore, lens filters cannot be attached directly to the camera.
Filters with 55mm diameter can be attached to the SP-570UZ via the CLA-10 Lens Tube Adapter, sold separately. However, it is not recommended because vignetting may occur in the corners of the image when the camera is set to wide angle positions.
The CLA-10 Lens Tube Adapter (Item #202104) is available from authorized Olympus dealers and also online from The Olympus Store: http://emporium.olympus.com
Apr 26, 2010 | Olympus SP-570UZ Digital Camera
Olympus SP560UZ digital still camera ''zoom error''
Hello
Regards
Andrea
Sep 20, 2009 | Olympus SP-570UZ Digital Camera
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
'zoom error' on olympus sp-560 uz
I had this problem and managed to fix it. The camera was dropped on a stone floor and the zoom error was present every time it was turned on. A ring or other piece of the lens was bent or damaged, in my non professional opinion. A profesional repair is my advice. However you may try my fix at YOUR OWN RISK.
Switch camera on, when zoom extends, but before it closes down due to zoom error, gently but firmly push lens back in. Drop batteries for camera to reset itself. Repeat, if necessary.
My camera now operates fully and when the lens extends it now no longer makes the slight grinding noise.
Good luck and remember at your own risk.
Jul 30, 2008 | Cameras
Combining zoom modes for closer long range photos
Hi, if you go into camera setup and make sure that the digital zoom is on then the camera will automatically go seemlessley from optical to digital zoom when the maximum optical zoom is reached. The digital zoom can only be used in certain modes, so if you cannot change the digital zoom to on because it is 'greyed out' change the camera shooting mode. please can you clarify the second request. Kind regards
Mar 18, 2008 | Olympus SP-570UZ Digital Camera
Olympus SP-570UZ Digital Camera Logo
720 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
