Question about Kenmore Elite 45986 Front Load Washer
Kenmore washer flashing f71
Anymore know how to fix it. the machine is dead and won't power on. thanks.
  • 135 Answers
These machines are very touchy and go out of balance easily. You may find success by unplugging the machine for 10 seconds and plugging it back in. Also consider releveling the machine. If you may have overloaded it, avoid that in the future. hope this helps!
Posted on Jan 06, 2009
What do the following codes mean: F70 and F71. My washer is a Kenmore Elite HE5t. Thank you
The F70&F71 mean basically the same thing
F70 means the main control board is not communicating with the cycle selector/touch pad control
F71 means the cycle selector/touch pad controlis not communicating with the main control board
What needs to be checked is the wires between the main control(CCU) and the selector(user interface) for good tight connections
If all connections are good and tight the CCU has to be replaced IF the drum will rotate under power from the motor
OR if the drum will NOT rotate under power of the motor the USER INTERFACE needs to be replaced
Gene
Aug 18, 2011 | Kenmore Washing Machines
My washer is not operating properly. please tell me what code F71 means and how to fix the problem. Thank you.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Dec 11, 2010 | Kenmore 47081 Front Load Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
He5t washer keeps flashing F71.
The F71 and F70 are difficult error codes to pin down even for a technician.
The F71 indicates a user interface heartbeat error while the F70 indicates a heartbeat error in the central control.
There is a quick test you can try to resolve the problem. 1. Lock the control by pressing and holding the cycle signal button. 2). Press the Power button.
3). If the lock light flashes when you press the power button it indicates the center interface was able to take the input and the Right hand User Interface received the DCV signal from the Center User Interface but since the display did not light. This indicates an issue with the Right hand user Interface.
To know more about this error code.Please click on the link below:--
http://media.fotki.com/1_p,srgbtrqsqqqggbqxgtqsskgwtqkq,vi/dkrssrqrrxkktggsfswxrrttkgswb/1/1303472/5961857/image257713813124371901img-or.jpg
to know where the parts are located on your unit ,please click on the link directly
http://media.fotki.com/1_p,srgbtsktrrbtqqdxgtqsskgwtqkq,vi/rbkfdkgkwxbqtftkggsxrrttkgswb/1/1303472/5961857/image9163592655485290914img-or.jpg
to get required parts you can get it from www.repairclinic.com.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 09, 2010 | Kenmore Washing Machines
I have gotten F70 and F71 messages and the door will not open. What do I do about this?
Hi.
Regards.
Ginko.
Jun 23, 2010 | Kenmore Elite 45986 Front Load Washer
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Regards.
Ginko.
Jun 06, 2010 | Kenmore 47081 Front Load Washer
No communication between UI and CCU
Hi.
I think that by this time you already fixed the problem. The codes indicate usually a fault that is either CCU or MCU.
Regards.
Ginko.
May 03, 2010 | Kenmore Elite 45986 Front Load Washer
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
135 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
