Question about LG LSC26905TT Side by Side Refrigerator
Freezer and ice maker stopped working
Food in freezer is thawing, ice maker not working. There is a huge build up of ice in the back. Will defrosting the freezer fix this?
    Scholar:
  • 86 Answers
Hi, Your problem will be fixed for a short time by defrosting the appliance but you really need to know why it is doing this? It could be several reasons for it! The main cause is that the defrost heaters have failed and so it does not deforst enough before it starts feeezing again causing the ice buid up again! Check them with a muti meter just to make sure. Let me know how you get on!
Posted on Jan 06, 2009
Auto-defrost refrigerator freezer ice build-up
Check vents/grills to make sure they are dust free. May need to be replaced. In meantime, leave freezer door open to thaw away ice (remove food not wanting to get thawed)
Mar 06, 2014 | Kenmore Refrigerators
Icemaker stopped producing ice so I removed. It had a burnt electrical smell. Two days later I opened the freezer door and it looked as though everything was thawing. Now the refrigerator portion is not...
ice mker may have not been the problem . there are heaters in the back and they may have been causing the smell and if they overheated due to a failed defrost therm. ck for ice build up in back of freezer . this would also cause ice build and a blocked evap coil .. and thus no cold to the fresh food . mm
Oct 14, 2010 | Kenmore 53632 / 53634 Side by Side...
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Kenmore 253.56953601 freezer isnt working properly. food is slowly thawing and ice maker stopped working
I think you have a defrost problem. Look at the inside lower back panel of your freezer. If I'm correct, you will see ice built up. You can take the panel out, defrost with a blow dryer. (After defrosting you can check your heaters. I'm sure you have a bad heater) You can put panel back in and turn the unit back on. It will run ok for around 3 days, This will give you time to repair or get repaired without loosing you food.
Please rate solution
Oct 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I am removing the back panel of the freezer because something with the defrost isnt working. Freezer has ice/frost build up. hany tips on how to defrost from here until the repair guy can come around?
One easy way is to unplug it and let it thaw out on it's own... get a couple ice chests and put you food in them and unplug it overnight...works wonders!
Jul 30, 2009 | GE GSH25JFR Side by Side Refrigerator
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Kenmore Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
139 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
