Question about Dell Inspiron 1000 Notebook
Fresh install thank you for your suggestion. However, I tired those steps has well and when I press F12 during startup nothing displayed has yu stated. I am talking about a dell inspirion 1000 laptop.
  • 14 more comments
  • floyd randolph Jan 06, 2009
    Thank you for your support and help I am presently running the FN will notify when finished. Once again thank you so much for your help.
    during testing of express test recieved error code 0F00.136C: Msg IDE device failed: Blank media or no media is present in optical dive. Test requires edia with digital data (Resouorce CD, Installation CD). I click continue testing.
    document not available
    ok followed yr steps document not available left battery turned on laptop and it is running windows setup has we speak.
    i am at the license agreement to installing win XP i guess to install not repair that is correct?
    ok hopes all goes well
    created a new-Partition3(New ) 2259 MB <2259 MB free> on 28616 MB Disk 0 on bus 0 on atapi {MBR}.
    oops did not do that
    suddenly lose pwr restarted and rec'd windows root>system32\haldll want re-install a copy of the above file.
    ok back at setup following yr previous command using ntfs quick option.
    Just want to say thanks to you for all your support in this. I do have a friend who is having a similar problem in doing a fresh install who lives in Oakland,Ca. I will send her to FixYa.com have her join hers maybe be a little more complicated may need a online chat session. Will notify her today once again thank you.
    One other question before I leave this will alleve programs running in background and maybe bring back to manufactures spec thereby a little faster?
    total physical memory 256 MB, available physical memory 120.52 MB. total virtual memory 766.55 memory. available virtual memory 586.76 memory
    how do i get the necessary drivers to complete reinstall. can't find drivers to rund my wireless adapter and other appl. seem to be worst now than when i started.
  • floyd randolph Jan 07, 2009
    Thanks but the real problem is I can't install Windows XP because it states product key is invalid. Went to systems and copied the key that was there and there is not 25 number/letters there. So now I have an empty laptop.
    Ty Rakesh
    I will try product key on bottom and has for wireless will get back to you. my yahoo messenger is randys_yang@yahoo.com.
  • Anonymous May 11, 2010
    Hi
    Thank you for the invitation.
    We will first run a small diags and check that the system is ok. If the system diags passes then I think we will begin with re installation. Also let me inform you that re installation takes a little bit of time so be patient through the steps as well.
    First ran a small diagnostics by pressing FN+ Power button and then turn on the laptop.
    It will take you through a series of diagnostics. Follow the prompts.
    If this passes let me know. This will make sure that the hard drive, memory, and the system is good and we can begin with OS re installation. Do not worry I will take you through these step by step.
    Also please make a note in some of the older dell laptops the Fn+power button does not work. let me know if that is the case.
    please posts the results of your diagnostics.
    Thank you
    Rakesh
    Dell Laptop Expert
Thats ok so I believe the HDD and the memory diags have passed and no error codes. Make sure the windows XP CD is there in the drive and turn off your system. Now try this remove battery and ac adapter.Press power button for 10 seconds. then connect only the ac adapter. Here is the link for instructions on how to boot from the CD.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4F6B48DB99ACDA78E040AE0AB7E15F49&journalid=5F92BDA5083A9D4AE040AE0AB6E15F8D&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
Follow this and let me know if it works
Posted on Jan 06, 2009
  • 10 more comments
  • Anonymous Jan 06, 2009
    http://support.dell.com/support/edocs/sy...
    here is the complete documentation of how you can reinstall the XP on a dell system
    Here are the links
    http://tinyurl.com/7b4agw
    http://tinyurl.com/98f6ph
    let me know if these does not work.
    So thats very good. So you have begun the windows installation. Do you have important data then do no delete any partition otherwise delete all partitions create a new partition and then install the XP on it.
    http://www.microsoft.com/windowsxp/using...
    Here is the XP installation Guide
    Repair option only when you wanna save the data already there. most of the time does not work but can give it a try. If you are not worried about data loss just continue installing XP.
    Delete the old partitions as well
    use ntfs quick as the option in the next screen
    ok then you might have to start from the beginning
    Now try this remove battery and ac adapter.Press power button for 10 seconds. then connect only the ac adapter. Go to one time boot menu go through xp setup and then delete all partitions and then create a new partition and install xp.
    Yes your system should be faster now. Let me know the memory available on the system you can get the information by typing msinfo32 on start run window and click on ok and you can probably upgrade its not that costly.
    Thank you for your feedback and I hope that I would be able to help more people like you. This is my first active day in fixya.
    Thank you
    Rakesh
    Dell Laptop Expert
    http://rakeshinnovation.blogspot.com
    Seems like you have the maximum that can be upgraded to.
    i would suggest that do not uninstall applications that you do not use often in the laptop. Then it should just work fine.
  • Anonymous Jan 07, 2009
    Hi which is the wireless card that you have? I can get the drivers for you.
    I believe you use the CD that did not came with the laptop. Dell Cds are preactivated so they do not ask for the product key. You can also find the product key on the bottom of your laptop if the system came with XP also you can ask dell to ship the media across to you. They will send you the media even if the warranty has expired and media or cds that they send do need a product key as they are all pre activated. If you need help in wireless I can definitely help. Post your gtalk or yahoo meseenger ids. I can take probably a remote connection and get it done for you.
    thank you
    rakesh
    Dell Laptop Expert
What can i do to get to the recovery screen on my gateway desktop, its model is SX2110G-UW24?
I pulled this from the Gateway manual for your machine. It is a generic guide. If this doesn't work, you may not have a recovery partition on your hard drive and should have made recovery disks when originally getting the unit. Good Luck!
From the Gateway Manual......
Recovering from the hard drive during startup:
To reinstall Windows and all pre-installed software and drivers:
1. Turn on your computer, then press Alt+F10 during startup. Gateway
Recovery Management opens.
2. Click on Restore system from factory default.
Caution: Continuing the process will erase all files on your hard
drive.
3. Click on Next. Your hard drive's original, factory-loaded contents are
recovered. This process will take several minutes.
Jan 11, 2015 | Gateway Computers & Internet
Need to reset password for windows 7
Do a web search for reset password windows 7 and you'll find many utilities to do that. You may have to burn the software to a CD using a different machine, insert the CD in the locked machine and run the CD. Some systems aren't set to boot from CD if it's inserted, so you may have to press F12 repeatedly during startup (or another key, usually displayed on the screen during startup) to select the CD as the boot device. Some newer systems can boot from a thumbdrive, so you could try that startup selection too, if you save the download to that device.
Dec 14, 2013 | Dell Inspiron Computers & Internet
I have an Amilo Pro V2035 and when switching on it only display 'BootMGR compressed.' I'v tried to press Ctrl+Alt+Del but nothing has changed. Pliz help me how I can restart the Laptop.
press F12 for boot manager before the screen displays bootmgr compressed.. Sounds like your hard drive may have developed a problem. When you press f12 you should get some startup options.insert your OS CD
go to DOS window and type in your OS drive (usualy C:\)
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
Oct 18, 2013 | Computers & Internet
Dell xps m 1530 my windows freezes on the startup screen i pressed f12 on startup and then chose diagnosis, i then got the error 2000 - 0146 linked to hdd1
This error means that your hard drive needs to be replaced.
If your laptop is still under warranty then you may want to send it for repair.
If it is not under warranty and you want to replace it yourself, then you can just follow some simple steps.
Dec 28, 2010 | Computers & Internet
I want to reformat my laptop, what steps could i d...
Hi, here are the steps in reformatting your laptop...
back up the files by connecting an external hard drive on it. If you don't have that, try flash drive...
If you have a windows CD, insert id on the disc tray.
Turn off the pc.
When turning it on, press F12 repeatedly until Boot Device Menu occurs
Then Select CD/DVD ROM drive
then Press any key to boot from CD
then wait for the prompt and select English for WIn 7
Then select partition 0 to initiate the startup in installing a fresh copy of windows Operating System
It will take 1 hour to 2 hours to finish the installation
May 16, 2010 | Computers & Internet
How to enter to boot menu
Try to press F12 during startup. You need to press F12 before windows starts to load.
Another option is press F2 during startup and change the boot device in the boot device priority section.
Done that Save and Exit setup
Mar 13, 2010 | ASUS F3Jm Notebook
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
Logitech keyboard F Lock works but nothing else Connectivity?
Reply to this issue from Logitech Tech Support:
Thank you for contacting Logitech Technical Support. My name is Susan and I will be assisting you with Incident # xxxxxx-xxxxxx .
I understand that the keys on your keyboard are not responding except the F lock key and the battery indicator key. Please correct me if I misunderstood you.
It appears that your keyboard might be encrypted during first installation.
To try and resolve this issue, I would like you to try and decrypt your keyboard. You can refer to the steps below on how to do this:
1. Press Ctrl + Alt +F12 key on the keyboard.
2. Press the Connect button on the receiver.
3. Press the Connect button underneath the keyboard.
4. Press the ESC key on the keyboard.
Once you have performed the steps above, test the keyboard in simple text applications such as Notepad or MS words to verify if the problem persists.
Additionally, you can try the following steps should the steps above was unable to resolve this incident:
a. Press the Connect button on the receiver for 10 seconds.
b. Wait for 20 seconds and then press the Connect button on the receiver again. Press the Connect button on the mouse.
c. Insert fresh new batteries back into the keyboard.
d. Press the Connect button on the receiver.
e. Press the Connect button on the keyboard.
This would help to isolate the cause of the incident that you are experiencing.
If this does not address your question, please update this incident, describing the results after following my suggestions. Or, if you prefer, you can contact us directly by the phone numbers listed below.
Thank you for choosing Logitech.
Sincerely,
Susan
Logitech Customer Support
www.Logitech.com/support
Dec 03, 2008 | Logitech Cordless Desktop EX110
HP Omnibook xe4500 on boot up says PXE-E61 Cable missing; Operating System Not Found. Wha do i do?
hi,
Selecting and un-selecting drives in BIOS can be a tricky process...let's try this: a) Step 1: go into BIOS, select F9 ( restore defaults) then F10 (save and exit). Re-boot. b) Step 2: back into BIOS, go into "startup" then into "boot" and choose "diagnostics". F10 to save and exit. Re-boot. You should be able to see both your drives (DVD and HDD) while "diagnostics" runs its course during boot. If you have a drive missing, there's your problem. If you don't have a drive missing, back to the previous idea: press F12, choose to boot from CD-ROM and see what happens this time around. Good luck and let us know. Install a fresh copy of windows xp. Thank you.........
Sep 14, 2008 | Computers & Internet
Startup with F12
Welcome to FixYa! Delete is the BIOS setup key at POST. F12 is a one-time boot option. Safe mode is accessed by repeatedly pressing the F8 key at the first Windows splash screen. Post again if you have further questions. Steve
Aug 05, 2008 | HP Compaq nx6125 Notebook
Dell Inspiron 1000 Notebook Logo
260 people viewed this question
Alun Cox
