Question about HP LaserJet 3015 All-In-One Printer
Cannot send or receive fax's with hp laserjet m1319f
Running an analog phone line through an cisco ata digital interface
    Genius:
  • 2,120 Answers
Fax machines are ANALOG devices.
Posted on Jan 10, 2009
HP M1319F Stop Printing Fax Error Reports.
go to the fax repots,conformations,their u select send only.
Dec 02, 2011 | HEWLETT-PACKARD LaserJet M1319F All-In-One...
I have a Hp m1319f all in one printer/fax and we cannot send or recieve faxes at the moment. we have dsl hooked up to it and also when the number is dialed to the other fax machine, you can hear the other...
You state you are using DSL. Do you have a proper DSL filter on the line going to the fax machine. If not then the noise generated on the line by the DSL will cause fax send/receive issues.
Apr 04, 2011 | HP Laserjet M1319F Laser Multifunction...
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP LASer jet m1319f mfp errors no entries in fax log
check that it is connected to the phone line, if your phone line is working your fax system also work
Jan 07, 2010 | HP Laserjet M1319F Laser Multifunction...
My HP M1319f fax machine is having trouble sending faxes only to certain phone numbers. Is this a problem with the actual machine, or the phone line?
I have purchased the HP M1319f multipurpose machine 1 year ago and expected it to print as well as fax. Sadly to say 1 year later, the printing works as expected but the fax never worked consistently for me. The solution I found was to buy a used fax machine and only use the HP M1319f as a printer.
The problem I've read about this problem on HP forums was the fax speed of the M1319f. It is locked to 28.8k which means it is only able to communicate with some fax machines. Older machines that doesn't support 28.8 will get errors and the fax will fail. This is definately an HP problem but considering I purchased this 1 year ago, this problem will never be fixed. Avoid this printer at all costs if your considering to use the fax machine.
Oct 19, 2009 | HP Laserjet M1319F Laser Multifunction...
We have an HP L7780 and have problems rec. faxes - error 232
Hate to say it, but it means "Don't buy HP printers". You'll be a whole lot happier with Canon or Epson. I had no end of trouble with more than HP all-in-one. They just get flaky after awhile, and the software (particularly scanning) is terrible.
Apr 18, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
2840 LaserJet All in One
If you have a digital phone service like Vonage or your ISP is a cable company that offers phone service, then you're digital as well, and your fax machine has an analog modem, the two devices will not work unless the phone company puts a filter on that will simulate the analog signal and allow the fax to oeprate normally. Call them and ask them to please initiate the digital filter for your line. I wish HP would come out with a digital modem so the problem can be solved for us $800 all in one customers can use our fax machines again. HP's image is getting worse and worse with lack of solutions, and high dollar fixes they leave up to the customer. A modem swap out should be given to the customers who bought this item and was not told the modem was analog. HP won't do it, they only see $ signs these days.
Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Feb 22, 2008 | Epson Stylus Multifunction Inkjet Printer/...
HP LaserJet 3015 All-In-One Printer Logo
245 people viewed this question
Seeker5211
Seeker5211
