Question about HP LaserJet 4350n Printer
Renaming networked HP laserjet 4350n printer rename
Users cannot see the printer name change. As a result 2 printers with the same name apear on his workstation, and will not allow him to delete the old printer, or verify which is the correct one in the device properties.
  • 200 Answers
Restart the computer in safe mode and try and delete the printer. If that doesn't work download the the Kyocera print driver seleter from kyoceramita.com and use it to delete the driver.
Posted on Mar 06, 2010
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
My printer hp laserjet 4350n displayed error 49.FF05 SERVICE ERROR .what is the problem
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to http://www.hp.com for more information
May 27, 2015 | HP LaserJet 4350n Printer
I need to check HP printer 3050Jp610 network name matches access point network name
Best method, plug in network cable in power off condition.,
Powerit & take configuration page., chk ip address in it., if its matches 2 ur system ip family, map in drivers or else change ip address in printer through menu settings..
Sep 20, 2014 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 4350n, is always wanting to print from tray 1
Typical of this machine. You have worn out feed rollers in tray 2. There are three of them, two in the top of the machine after removing the tray and one in the tray itself
May 21, 2013 | HP LaserJet 4350 Printer
Hp laserjet 4350 print problems
Two reasons: 1. cartridge 2. Trflon sleeve.
A.Check with another cartridgeB.Remove fuser assembly, check teflon sleeve surface,if its dirty or toner deposited on it replace it if you can or replace entire fuser assembly. Replacing the fuser assembly is user friendly.How to remove fusser: browse this youtube video link:
http://www.youtube.com/watch?v=j0Pi-eHgoSA
Nov 27, 2012 | HP LaserJet 4350n Printer
I bought a new machine hp laserjet 4350n but I cannot locate the power switch botton. Pls help me.
Hi, the power switch button (on/off switch) is shown as Number 5 in the diagram below, on the right hand side of the printer at the bottom:
Apr 12, 2011 | HP LaserJet 4350 Printer
Hp4350n
Set it in JetAdmin.
Jan 15, 2009 | HP LaserJet 4350 Printer
HP 4350n Printer says paper jam .
check the paper sensor maybe one of the sensor stuck
Feb 12, 2008 | HP LaserJet 4350 Printer
HP LaserJet 4350n Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
