Question about LifeView NoteCAM 300 Webcam
It Says I don't have a camera plugged in!!
On msn Messenger when I start a video call it says I don't have a camera plugged in. I know it's plugged in properly because I have gone to My computer and it says it's plugged in. I have installed all the things from the disk and have restarted the computer.
  • Olivia Web May 28, 2007
    Thanks, but i already have windows live messenger. I'll try it anyway and sorry for not saying it earlier.
    thanks!
    olive
    President:
  • 2,961 Answers
Have you gone into the msn messengers settings and options, as you have to enable the cam to be used, i would advise downloading winows live messenger; a newer version than msn and it's more stable than older versions
Posted on May 27, 2007
I don have my cd and i need download the software
Genius VideoCAM Messenger is the best choice for you to chat on MSN and share real image with friends is our latest VideoCAM Messenger. Follow this link to Softpedia to dowload the software... http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/GENIUS/Genius-VideoCAM-Messenger-20.shtml
Jul 12, 2010 | Genius VideoCAM Messenger Webcam
Not working with msn messenger
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Apr 06, 2010 | Logitech QuickCam Messenger Web Camera
I have installed the camera and it works fine in testing it.....but when i want to use to on MSN, it says there is no camera installed. i have unistalled and reinstalled but am lost how to get it to work?
HI,
First uninstall your msn messenger and then uninstall then webcam software/drivers.After that reinstall the webcam and then reinstall the msn messenger.
This should fix the issue.
Let me know the result.
Thank you for using fixya.
Nov 17, 2009 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Msn video not work
This problem are just like a yahoo messenger web camera show up in your screen but the other person cannot see you.
All you have to do is to check your internet connection probably is excellent and no other programs use it.
Often also is your Messenger if you have this problem Turn-OFF you MSN and Turn-ON again.
Or use a lower version of MSN Messenger. 100% work like MSN 7.0 or Beta.
Sep 13, 2009 | Microsoft Windows Live Messanger
Messenger
msn messenger 8.1download oer windows
para Linux usar messenger msn for linux Kmess
si tu non puoso instalar ... try ..MSN on web
las problemas con video llamada son con le driver per web camera ..si la camera non functiona con Kmess cerca on www.meebo.com ( sign in on Msn ..
Apr 09, 2009 | ASUS Eee PC 900 Notebook
Acer Aspire 7730 webcam can't use on MSN
you need to also set cam up for msn followAfter you start Windows Live Messenger,
expand the view by clicking on the square
on top left next to the red X.
Then on the Windows Live messenger window on the
right side, click on “ “Show Menus.” And then click
on “Show the Menu Bar”.
Next go to the Menu Bar on right side, click on Action.
Go to “TOOLS” and click “Audio and Video Setting
and follow the instructions.
these instructions
let me know if this helps
Jan 21, 2009 | Computers & Internet
Acer Crystal Eye Webcam and MSN Messenger
Make sure you are not running the Desktop Icon program first. The camera can only be used by one program at a time.
Now login to Messenger, and click
Tools > Audio and Video Setup, and click Next past the audio settings, and choose USB Video Device from the list. It should work after a couple of seconds. If that doesn't work, try the other device drivers from the list, waiting a couple of seconds each time, until you can see some output in the window. Then apply and you're ready to go.
It's the same deal with Skype, except it's in
Tools > Options > Audio Settings.
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Acer Aspire 5520-5908 Notebook
Straight from MSN helpdesk:
1. Click Start, click Run, copy and paste the following text: %SystemDrive%\Program Files\McAfee\SiteAdvisor in the Run box and click OK.
2. Right-click the file sasets.ini or sasets.dll and select Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini or sasets.dll and restart your computer
Kathie x
Jan 09, 2009 | Acer Aspire 5920-6727 Notebook
hi,the acer crystal eye has issues with mcafee site adviser either delete it as i did or configure it.search mcafeemessenger click on microsoft live messenger 2009 (v140) conference link to the appr opiate page hope this is helpful.
Mar 19, 2008 | Acer Aspire 4315 Notebook
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
LifeView NoteCAM 300 Webcam Logo
198 people viewed this question
Top LifeView Computers & Internet Experts
Alun Cox
Are you a LifeView Computer and Internet Expert? Answer questions, earn points and help others
