Question about Dryers
My gas dryer stopped turning.
During a regular drying cycle my dryer made a loud noise and then stopped spinning. It was hot, just not turning.
Whirlpool HD Extra Large Capicity 5 cycle temp.
Model: LGR5644EQ3
Type: 121-00
Seril # MH5101282
  • 594 Answers
There are two options on why your dryer would stop turning.
1. Your dryer motor quite
2. the dryer belt either came off or broke.
you will need to take the dryer apart to see if the belt is broken. if not than it is your motor.
Please let me know if you need further assistance in this matter.
Thank you for choosing fixya. please do not forget to rate and comment about your experiance.
Posted on Jan 06, 2009
Dryer makes loud noise and does not spin
had that problem once and it turned out to be 2 problems....the first was the belt that snapped..replaced it and it did not work turned out to be the pulley on motor broke
Dec 17, 2011 | Dryers
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Inteli dry regular cycle, timer gets stuck and won't advance. other cycles work fine. thanks
An unusual noise coming from a running clothes dryer can cause concern, although these noises are rarely indicative of a more serious problem. Once the source of the noise has been located, a few simple repairs or adjustments will usually solve the problem and restore peace to your laundry room.
    Gas
  1. A gas dryer may emit an occasional clicking sound. This noise is caused by the gas valve and is a normal operating sound. The clicking sound coming from the gas valve can not be eliminated and it does not indicate any mechanical problem with the dryer.
  2. Warm Up
  3. A newly installed dryer, or a dryer that has been left unused for a period of time, may exhibit a thumping noise during the first few minutes of the drying cycle. According to the Maytag company, this noise is normal and should not be a cause for concern. If the noise continues for more than a few minutes or repeats on subsequent loads, however, then steps should be taken to locate the origin of the noise.
  4. Clothing
  5. Clothing can become knotted and balled up in the clothes dryer. This can cause vibration or a load thumping noise. When this happens, open the dryer and remove the knotted clothing. Separate the articles of clothing and place them back in the dryer. The thumping noise should not continue unless the clothing has become knotted again.
  6. Vibration
  7. Place your hands on top of the dryer and push down firmly; if the dryer tilts to one side, the clothes dryer is not level. This can cause the dryer to vibrate during the cycle and if the vibration is severe enough, the surrounding walls could be damaged by the dryer. Maytag dryers have four leveling legs installed into holes on the bottom of the dryer. These legs are included with the dryer and should have been screwed into the holes during installation. A wrench can be used to adjust the legs until the dryer is stable and level.
  8. Foreign Objects
  9. Small objects such as coins, buttons, or paperclips can become lodged between the drum and the sides of the clothes dryer. These items usually end up in the dryer after being left in clothing pockets during laundering. Turn the dryer off and remove any clothes to a laundry basket. Allow the dryer to cool down so that you won't burn your hand on any metal surfaces inside the dryer which may be hot. Look inside the dryer and pay special attention to the front and rear edges of the dryer drum. Run your fingers along the grooves where the drum connects to the dryer to locate any foreign objects. These objects could be bouncing around the dryer causing noise during the cycle, and then settling into the grooves when the dryer stops making them difficult to locate. Remember to remove all items from clothing pockets before laundering in the future to avoid this problem.
  10. please comment on these solution on how helpful
Dec 30, 2010 | Maytag SDE5401AYW Electric Dryer
Buzzing noise
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | Samsung DV419AGW Dryer
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
Do I need a belt? It stopped spinning during rinse cycle.
IT COULD BE A BROKEN BELT , open front panel and take a look at the bottom , you might need a flashlight for more accurate visual , good luck , AJ
Nov 20, 2009 | Video Game Consoles & Games
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Dryers Logo
122 people viewed this question
Top Dryers Experts
