Question about Amana ARS2464B Side by Side Refrigerator
Refergirator not cooling
The freezer is working fine the refergirator is not cooling our model is a sise by sideARS2464B
    Novelist:
  • 161 Answers
Defrost system failure.
Defrost system: Freezer fan, Defrost timer, Heater, Thermostat. If any one of these are bad the coils in the freezer will get clogged with ice and not allow the cold air to circulate over to the ref. side.
Ice/frost build up on the back wall of the freezer is an indication of this problem. You can manually defrost with a hair dryer which will give you a couple of days before it starts iceing up again. Remember, the ice you see on the back wall is just the tip of the iceburg, there is a lot more on the coils behind that wall.
Posted on Jan 27, 2009
Why is ice build in my frost free/refergirator, and water dripping into refergirator?
Your Kenmore may not perform well in the garage environment. Since it isn't practical to move it back inside, you may have to abandon the idea of having a second operating unit.
Dec 15, 2013 | Refrigerators
Door seal on my Frigedaire sise by side gets hot, what is wrong?
I had this once with a Fridigare GLRS267ZAQ4 side by side but it was also heating up water and the freezer wasn't working very well.
My problem was that the coils and condenser in the back bottom of this unit needed a major cleaning and the fan wasn't working very well. Cheap to buy that part and replace yourself. This problem was causing this unit to heat up everywhere because the coils and compressor were not being cooled properly.
I have often found this unit to get ice build up in the back inside wall and had to take a hair dryer to it in order to melt the ice. This mostly caused problems with the ice dispenser and freezer getting warm.
Right now I am having a problem with my refrigerator not cooling well but the freezer is fine. Guess I'll try to defrost the ice and check the coils again.
Hope this helps!
Kyle
Dec 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer works but refrigerated sise does not cool
check that the evaporator fan is running or for frost covering the back of the freezer. If the freezer has frost at the back it it is a defrost problem. this model probably has a main board on the back. what is the model number and i can help you further.
Jun 18, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Highpoint sise by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 13, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator was working fine - this morning there is a puddle under the freezer door and booth sides of the unit are not cold. Compressor or reley continues to kick on for about 7 -8 seconds but will not...
Sounds like your compressor is laborring or on its way to seizing, either way it will soon fail, needs to be replaced. Depending on the age of the refergirator it may not be cost effective to have the repair done. Don't forget to check your owners manual to see if the compressor is still under any warranty! Good luck !
Nov 28, 2009 | Cars & Trucks
FRidge/freezer not staying cold
i would focus on the defrost heater or heaters behind the back wall of the freezer.this is kind of common.
Aug 06, 2009 | Refrigerators
Water dispenser not working
This water line does not run through the freezer. You have a switch in the door where you get water that activates the water valve in the back of the Ref.
One or both of these are bad and needs to be replaced.
Dec 21, 2008 | Refrigerators
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Freezer no cooling
check continuity thro the fan motor and check it rotates freely
Oct 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana ARS2464B Side by Side Refrigerator Logo
132 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
