Question about Kenwood KDC-MP228 CD Player
Will not play
The radio comes on but will not play anything through any of the speaker wires. I can here everything working,"the cd is turning,the tuner stations are showing up."The cd player is also ejecting every cd i put in it "original or burned" Thank You, rick217
  • 883 Answers
On the front panel, look for a tiny pinhole and insert a pin while powered up to reset
Posted on May 27, 2007
Last night I was playing a CD and hit a bump and the CD quit playing and the word PROTECT started flashing and now I can't get anything to play or get that PROTECT off there.
Check wiring behind the radio itself, also check speakers and wiring for them. When a radio or an amplifier goes into the protect mode it is protecting itself from an electronic short. If it turns on properly and has been for some time it is not the the power wires, but may very well be a bad speaker or a connection to that speaker.
Foraudiogeeks.com
Apr 13, 2016 | Car Audio & Video
When playing cds in my sony cdxgt500 the sounds come throught the door and rear speakers fine, but not through the subs. everything works as it should while playing the radio.
Hello.... it sounds like you have the remote wire for the amplifier hooked to the solid blue wire behind the radio. You need to hook to the blue/white wire behind the radio. What happens is that the solid blue wire turns on the power antenna when you are listening to the radio and it turns off (lets the antenna down) when you listen to a cd. There should be a blue/white wire that is the amplifier turn on wire that will stay on as long as the head unit is on. Hope this helped!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Sony CDX-GT500 CD Player
Put the radio in my truck about 4 months ago, worked great. the truck sat for months because it was broke, now i get it fixed, put the face on my radio and everything is on, my radio, my amp is running but...
Turn the volume up to the highest level.
Can you hear a hiss or static?
NO...usually means speakers are disconnected..often loose socket at rear of radio or broken wiring
YES...Hiss means either blown speaker, faulty radio or faulty aerial.
If you have tape or CD as well , this will prove whether it is the aerial or not.
HISS with CD or tape playing means faulty radio or speakers
WORKING OK with CD or tape means faulty aerial
Feb 20, 2011 | Car Audio & Video
My radio in my Yukon turns on but no sound comes out of the speakers. i installed an after market cd player and i still cant get any sound on the speakers
It sounds like the amp is not functioning on the radio. If you install and after market cd player the radio still won't play because it's the same amp.
Now, if you would change the radio and it still won't play, it sound like it would be the wiring to the speakers. Speakers usually don't burn out, but anything is possible.
I hope this helped.
Jul 16, 2010 | 2000 GMC Yukon Denali
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Speaker trouble
MAKE SURE NO SPEAKER WIRES ARE TOUCHIN THE OTHER, IF DONT WORK.. YOU WILL NEED TO TOUCH TWO WIRE AT A TIME, DID YOU HEAR SOUND BE4 INSTALLING
Mar 25, 2008 | Car Audio & Video
Eclipse headunit
There nay be a wiring issue with your amp. When you are running a CD more power and sound quality is envolved so the amp works harder. Check the amp make sure everything is where it should be.
Feb 11, 2008 | Car Audio & Video
Plays radio not cds
You may have Power antenna and amp remote turn on wires switched. Your system may be looking for turn on signal from radio and only gets it when am or fm is on because power antenna wire is hooked up instead of amp turn on signal.
Jan 18, 2008 | Kenwood Sirius KDC-MP522 CD Player
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Kenwood KDC-MP228 CD Player Logo
46 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
