Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
The colors are overlapping each other in pink and blue on my tv. i was hoping you could tell me what part i needed.
  • carlsberg33 Jan 11, 2009
    could someone tell me what i need to replace if i cant manually fix my convergence?
  • 43 Answers
It just sounds like your convergence is off. You should have a convergence feature on the menu.
Posted on Jan 08, 2009
  • dhurt Feb 12, 2009
    Nothing to be replaced. If you still have this problem, you need to resolder the convergence IC's on the convergence board.
I have some picture distortion - pink fuzzy color where white should be (like on hockey ice). I'm trying to determine if the t-con board is to blame and if I might fix it easily
Hi Bill.
I don't see a specific model for your TV, but have owned a rear projector system before. There is usually a sub-menu where you can do fine alignment of the Red, Green, and Blue projectors to get rid of the pink fringe. There is generally a white crosshair at center screen where you can fine align the three colors to get rid of the fringing, and sometimes an advanced menu where there are crosses all over the screen that you can individually select and fine tune, (tweaking the different optical distortions of the individual projectors to overlap).
If the fringe is a big swath instead of a fine edge, or if a color is totally gone, then you may be talking power amp issues. For fine fringes, the adjustments usually work fine.
Hoping that helps!
D
Dec 18, 2015 | Televison & Video
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
I need to know which connectors go to which O2 Sensors on my 2005 Jeep Grand Cherokee 4.7L 4WD. Can you help?
Hi, the easiest way to tell is by the signal wire color. These are the signal wire colors:
right front: dark blue/pink stripe
left front: dark blue/light blue stripe
right rear: Brown
left rear: dark blue/yellow stripe
Apr 17, 2011 | Jeep Grand Cherokee Cars & Trucks
Red green and blue colors do not overlap. Looks like a 3d movie without the glasses
Projection TV's sometimes need a "Convergence" adjustment. If you do not have the manual and/or cannot find the option in your TV menu, here is a link to help. Follow up and confirm this was your problem.
http://www.ehow.com/how_2034880_perform-convergence--tv.html
Jun 30, 2010 | Televison & Video
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Lines and blue screen on WS-55807 mitsubishi tv
Take your two front grills off ,try adjusting one of the 3 knobs for background color.
Feb 04, 2009 | Mitsubishi WS-55807 TV
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Canon powershot A560
an incandesant light above the stones and the camera without the flash should work.. thats how i was able to capture the pink of pink saphirres...and zircons.. hopefully it works for u
Jan 06, 2008 | Canon PowerShot A560 Digital Camera
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
