Question about Sharp AL-1642CS Copier
Paper feeder jams and crinkles the paper up
As the paper is copying and passing through the last roller before it exits to the tray, it is getting stuck and crinkled into a fan like jam. It sometimes makes it through, but the paper is wrinkled as it comes out.
    Novelist:
  • 148 Answers
There is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
Posted on Jan 06, 2009
Having constant paper jams - the paper does feed and the document prints about 3/4 of the page, but crinkles up before exiting the printer, like the slit where the paper is supposed to come out after...
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
I clean the rollers with Isopropyl Alcohol and the green kitchenlb_icon1.png scouring pads. When the rollers are shiny they often have white/grey markings on them. Keep scrubbing until rubber is roughened up.
Oct 14, 2013 | Brother MFC-7220 All-In-One Laser Printer
Two IR2270 is converted to IR3570, problem is when duplex printing, paper is getting rolled on the exit tray. During simplex printing paper is not getting rolled but it is wavery. Very rarely paper jam...
You may have a damp paper issue, when damp paper passes through the hot element it curls or crinkles the paper resulting in paper jams and poor output , if you turn all you paper round in the paper trays to A4R it will help, or use dry paper, recycled paper is the worst as it collects moisture much quicker, especially left over night
Oct 10, 2013 | Canon Office Equipment & Supplies
Paper jam I got the big piece of paper out but cannot find the small piece What can I do
Hi
The paper jammed can be found in the paper tray, inspect for a paper jammed and feeder roller.
It can be found in the cartridge compartment inside the printer.
If you use the top feeder when copying, it might be there in the top loader paper. open and inspect there
It can be found in the toner cartridge itself.
Lastly, it can be found into the back door of the printer. Check for the door both sideways or back door of the printer.
Mar 06, 2011 | Brother MFC 240C All-In-One InkJet Printer
Paper jam error message but there is no jam
usual problem is a paper sensor (most likely a small lever) has gotten stuck.. find the paper sensors and reposition them
Jun 10, 2009 | HP J4680 Office Jet All-In-One Printer
Image print on paper slanting
Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
Jun 05, 2009 | Canon NP 6545 Copier
PAPER TRAY JAM
Hello sir;Pull out the tray look inside the machineif you found any paper chip emove it otherwise clean out paper pickup roller with rubbing alcohol.
Jun 01, 2009 | Kyocera Copystar CS-1820 Black and White...
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Continual paper jams in rear of printer
Jan 03, 2009 | Brother MFC-7820N Printer
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
336 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
