Question about HP Compaq Presario V2000 Notebook
I have laptop of compaq v2000 this is dead how can i replace chip
I have laptop v2000 compaq i wana repair that laptop how can i repair & whos the chip of laptop v2000 when i replaced & solved my problem plz replyyyyyyyyy urgently
V2000 laptop is dead i check power supply all component
If your power supply is the problem then you can replace it with a new one from HP.
Mar 12, 2011 | HP Compaq Presario V2000 Notebook
Presario v2000 Laptop dead.
Its may be the problem on ur psu or ur motherboard
Jul 28, 2010 | HP Compaq Presario V2000 Notebook
Bios chip location on mother board
no,, reinstalll the vista,, the problem will not occur again
Jan 08, 2010 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 is dead!!!
Well oviously when you dropped it, it had done alot of damage. There is defenently something in there that needs replacement. I can't acctually see the inside of your laptop so i don't know what. Go see a computer pro.
Jun 09, 2009 | HP Compaq Presario V2000 Notebook
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. john@johnslaptops.com
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 battery
if the computer will turn on with it plugged into ac power than it is most likely the battery. batteries on these machines are cheap. Mine died after a year
Jan 18, 2009 | HP Compaq Presario V2000 Notebook
How difficult is it to install memory chip ugrade,,,
No problem in replacing the RAM chip modules, just make sure you ground yourself so you don't have any static electrical charge when you handle the memory modules.
Just power off the laptop before you remove and replace the RAM.
You won't lse anything as the info. is stored on the hard disk..
Jan 11, 2009 | Compaq Presario Notebook
Compaq V2000 Screen went dark
Have you try external monitor? If it's still same, the LCD screen back light or the inverter of the LCD screen was faulty, but yours most likely the inventor of the LCD screen was faulty, it's only can be repaired by components level tech.
Nov 23, 2008 | HP Compaq Presario V2000 Notebook
Compaq V2000 Dead
I also have a v2000 which has suffered the fate in the passed, unfortunately as i'm sure you've already read you will probably require a replacement system board.
May 25, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 no power new dc jack
I think that this can be rated as solved. If it is not solved please let me know.
May 21, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
