Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
I have a 2640b router failure
Power light is showing red (usually green I think) LAN light works but it will not connect to the internet. I have tried resetting it, changing position of lan cable and turning powere on and off. Any ideas?? many thanks
I think that u need to go on, open your internet explorer, and enter your ip address in the address bar. Enter your password. Check your settings. Sometimes, internet stops, because firmware needs to be updated, sometimes its your computers driver (this is not likely); but most likely, your best option is to update the firmware for it. Consult your manual or internet on how to do it.
Posted on Jan 06, 2009
Red flashing light on D-Lonk wireless router dsl-2750b
Means you have no internet connection. Try a new LAN cable between you router and internet modem. Connect directly to you internet modem make certain it is working. Reboot both devices.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Nov 27, 2013 | D-Link ADSL2/2+ Modem/Wireless Router...
Modem d-link dsl 2640U status : connected Power : Red Light LAN (R1) : Green Light DSL : Green Light Internet : Red Light seems that the modem has crash! can't even rest it ! so what should i...
I am techbuddies from fixya .i would like to give a try on your issue.
first of all shut down your modem and your computer then unplugged cables that goes from modem to your computer once it is done then wait for 30-50 sec and then replugge all your calbe and then first turn on your modem and then your computer .This kind of method is called as power cycle of modem.
Once you have done that then check that wether is works or not if not then try to check that is their any kind of red X on your computer on right hand side bottom ,if yes then on run type devmgmt.msc then click OK and the you would be able to log in to device manager .Once the device manager is open look for network adapter click on the plus sign and then under lan right click and click on to enable it .
check wether your internet is working or not .
Also check what is the ip address if comming on your computer .
Inoder to reset your modem .check is their any small hoel in rare-end of the modem if yes please insert a smal pin in to it and press it untill all light flash on and off .
if still the problem comes get back to me on fixya
Sep 09, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
My DLink DI-604 router is not working properly. Lan port 1 I think is not working and only one computer connected to the router can connect to the internet. So I tried to remove all ethernet cables,...
Having an issue with your router or other equipment rented or purchased from Verizon Fios? Contact customer support service number 1-800-243-0019 for help. Our technical experts.
Apr 15, 2017 | D-Link (DI-711) Router
Cannot connect internet as it shows internet is offline
Always check your LAN cable between your modem and the router and try a new cable. Login the make certain your router is configured correctly to connect to your mode.
Jul 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Internet turns red after 10min of restarting and resetting router
Please make sure that the router is properly configured then only the internet light will be green
Talk to your ISP regarding the router configuration
May 03, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
After a power failure, the internet light in my router is red. I tried all the usual, switching on and off, resetting, disconnecting from phone and power line for several hours. Nothing makes the internet...
a red led usually indicates an error or defect. if removing the power for several minutes (or hours like you did) does not reset the error, then i'm afraid that you will have to replace the device completely. however, the root cause may still be found before the router. have you tried unplugging and replugging the modem as well?
Apr 21, 2010 | NetGear DG834G Router
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
430 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
