Question about RCA RS2040 CD Shelf System
RCA RS 2040 - no sound output from speakers or earphone outlet,
The all other functions seem to be working well.
  • 1 more comment
  • in_need525 Jan 31, 2009
    I have the exact same problem. No sound output from speakers or earphone outlet, but seems to be working other wise.
    I meet to add to the post that I would like a schematic for it if some had one I could use.
  • Anonymous May 09, 2009
    I have the exact same problem, too. It looks like everything else lights up. CD plays. No sound from speakers or headphones. This was in my husband's office. He was not abusing it. It was not being moved. It just quit working. It is only 2 1/2 years old. It seems heavy duty. I hate to toss it in the trash if there is a simple fix. He already bought a new one for his office.
  • 10 Answers
SOURCE: RCA L26WD26D
Did not work..
Posted on Mar 12, 2008
IB4G2008
  • 3587 Answers
SOURCE: RCA RT2760 problem
sounds like you may have blown the internal amplifier circuit.you a handy sort of person?
Posted on Apr 20, 2008
  • 41 Answers
SOURCE: RCA 1997 TV - sound not working
check the speaker...for continuity...
Posted on Sep 03, 2008
SOURCE: rca rs 2620 power but no audio
I had the sane problem: No audio out from any source. Although I was unable to find a schematic or service manual, I did find the defective part was labeled on the circuit board as Q401 and replaced it with RadioShack part number 276-2009 (MPS2222A NPN Transistor TO-92 case NPN silicon). This is not an exact match, but is available at most RadioShack locations for under $1 and has fixed the problem.
Posted on Jul 30, 2009
ImpalaGuy
  • 60 Answers
SOURCE: Can I hook up my PS3 to the RCA rs 2030 for audio
Unfortunately, I do not believe so. The Optical port on that machine is for Output only, not input.
Posted on Mar 03, 2011
Testimonial: "Quick Response. Not the answer I was looking for, but I appreciated how quickly ImpalaGuy was able to help."
A model TC-P42x60 and I need to use earphones. I have tried the audio outlets using a rca cord with a 3.5mm plugged into a set of earphones, that does not work.
There are no audio outs on your TV The digital audio out is an optical output meant for a sound bar or a stereo audio amplifier that has an optical input. If you have a compatible stereo system you can use an optic cable to connect the two and then use the headphone jack on the stereo system.
Aug 05, 2017 | RCA Audio Players & Recorders
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Does my RCA sound bar Model # Rts7110B-2 have bluetooth output for earphones?
The earphones and the sound bar have the same functionality: they are RECEIVERS of sound from an audio source, i.e you cannot connect one to the other (and anyway, what would be the point ?). You connect the soundbar to/with an A/V system, a TV, etc. You connect your earphones to/with a computer, laptop, phone, tablet, etc.
Jan 10, 2015 | RCA Televison & Video
Rca rtd 6151
You may have to connect the subwoofer output to a powered subwoofer.
Dec 01, 2013 | Audio Players & Recorders
I have a mid tablet that i bought new from amazon. the internal speakers worked fine untill i put some earbuds into the jack. what is the safest and most inexpensive way to fix it?
Well, you need to find out what happened. Normally, the earphones will cancel the internal speakers, but the function of the speakers should return after you remove the earphones.
What you need to do is go into the control panel and then to the sounds icon and find out what the system is using for its output. It could be that it thinks the sound should be still going to the earphones. If so, change it to speakers.
Aug 22, 2011 | Computers & Internet
My Sennheiser RS 110 headphones won't work. I followed the installation directions but all I get is static. What else can I do?
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
Jan 02, 2011 | Sennheiser RS 120 Consumer Headphones
I have a Vizio Flat Screen TV. I have speakers in all the rooms in my home. Can the TV be hooked up to the speakers with any success?
yes, the TV can be hooked to the speakers, but you will be needing a receiver (amplifier).
Check your TV, if you will have any earphone input space. If you find it on the TV, then it means job is half done.
Get a 3.5mm to RCA cord, connect the 3.5mm part to your TV's earphone space (if any), then connect the RCA part (Red and White) to input (Aux/Video/CD in etc) at the back of your receiver (amplifier) or deck, select the input (Aux/Video/CD in etc) on your sound system (receiver/amplifier) and sound should come out of the speakers.
Also, you can use this same method, but this time with a different wire which is RCA to RCA.
Connect the RCA (Red and white, to "Output" or 'Out' at the back of the TV, then connect the other part to the "Input" of your sound system (receiver/amplifier).
Good luck.
Dec 02, 2010 | Televison & Video
N no sound
Hello
you just start from speaker first. if the speaker is out there will be no sound output from your TV. To confirm this, just plug in an earphone or headphone pin into the headphone or earphone socket , if provided, on the TV. If sound is available through headphone, it means that the sound output section of your TV has no trouble, but the speker is out. Replacing it with same type and number will resolve your problem. If there is no sound fron the earphone too, surely the sound output section inside the circuit board of your TV has the fault.
If so you have to open your TV. Locate the sound output stage, which can be easly locted through following the speaker wires. There will be an Ic [Sound Output Ic], normally screwed onto a metal plate, to radiate heat out when it works. Check for any bad solderings at the legs of that Ic by tuning the printed circuit board upside down. It is very difficult to locate loose solderings. i always do is, resoldering the suspected solder points by applying a little more solder. You also do this first. If it does not help, resolder the Ic out from the circuit board, and go for a same type and number. Replacing it will solve your problem. In some RCA sets, sound section is built out on to another board. Locate it and do the same. OK.
Nov 13, 2010 | RCA F32650 32" TV
My S Video from laptop works with TV however no sound on TV
No, S-Video is video only. Look for the Audio output jack on your computer (usually its a lime green earphone hole). you will need a 3.5mm to RCA Stereo output wire, and attach the RCA audio to the AUX input of your TV, and then hook it to the Earphone/Speaker output jack on your computer. Then you will have to set your computer volume at about 75% (not all the way up, but more than halfway up). Then you can adjust the volume on the tv set. (just fyi, if you have bass boosting on the COMPUTER, turn that off, as well as any Equalizer or BASS/TREBEL booster. Set your mixers and boosters to NORMAL for best sound. not doing so could produce popping or scratching in the sound from the TV, also, if you have your PC volume higher than 75% that can also cause popping)
Aug 28, 2009 | HP Pavilion Elite M9150F Desktop PC
RCA RS2040 CD Shelf System Logo
51 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
