Question about Palm Tungsten T5 Handheld
T5 reset locked the screen at "Palm Powered"
Was using a program (Epocrates) and went to home to switch to another program. The entire screen went blank. Tried the "home" button again and nothing. Performed a reset on the back of the T5 and now the screen is frozen on "Palm Powered" no matter what button i push or how many times I try to reset it. Also it does not shut off automatically either.
    Sergeant:
  • 237 Answers
OR just update your software for the device, sometimes just an updated software will fix your problems...
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=261,E=0000000000208968933,K=9734,Sxi=6,case=obj(2630)
Posted on Jan 06, 2009
    Sergeant:
    Champion:
  • 304 Answers
If you are using an sdcard try to power on the unit without it.
  • Palm Master
  • 19,396 Answers
Try the reset published here: T5
  • Ginko
    Ginko Jan 06, 2009
    Sorry, the Palm link was not available anymore, try reset here: Reset Primer
  • Palm Master
  • 13,433 Answers
Perform a hard reset
instructions on the palm website:
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,CASE=obj(887),ts=Palm_External2001
If you are unable to perform a hard reset we need to either disconnect the battery, if not removeable then you need to let the palm drain all its battery to empty and then plug it into the charger again. it may take up to a week to drain the battery.
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
It died! wont reboot I just get the palm powered
You got corrupted phone software that is why your phone won't boot up. The best thing here to do is take out the memory card of your phone. Power on your phone without the card. Now if the booting is successful. format the memory card using a card reader and place it back to your phone after doing it.
Dec 18, 2009 | Palm Tungsten T5 - Multilingual Handheld
Wont run Epocrates RX
Your Device runs Palm OS 4 and appears not to be compatible in it's current state. However is you can upgrade to PalmOS 5 or higher it will install and work.
here is a link for epocrates RX comptibility:
http://www.epocrates.com/products/rxpro/requirements.html
Here is the Specs on your device:
http://pdadb.net/index.php?m=pdamaster&posted=1&os=p400
You may need a device with Palm OS 5 or higher
Jun 10, 2009 | IBM WorkPad c500
Tungsten E2 just stopped while adding data said fatal error
Well had to do a hard reset- lost everything, had no back up, long story don't think I'll bother with palm ever again!
Apr 11, 2009 | Palm Tungsten T5 Handheld
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
Treo 755 with epocrates
I found that when I moved epocrates off of the storage card and into main memory, it didn't have any boot problems any more...
Sep 09, 2008 | Palm Treo 755p Smartphone
On/off switch
I am pretty sure this is a software problem, not a switch problem. The T5 is the Ford Edsel of the Palm range, with many unsolved bugs. I fixed this problem by using shortcut for ON and OFF.
Switch ON:
Use one of the 4 application buttons. The default house button opens the Palm at the menu, but you can change any of the buttons in
Preferences > Personal Buttons
to open whatever application is convenient.
Switch OFF
In
Preferences > Other Offstroke
check Enabled, and Pen Stroke or Screen Tap (or both), and then select the gesture that will turn off the Palm. I use "Screen Tap in top left corner" to turn off.
It's not a real solution, just a workaround. I also flushed and reset the T5 and reloaded from backup, and the problem went away for a while, then came back. It gradually takes longer and longer to switch on and off. There is some bug in the OS, but Palm doesn't seem to care about it.
Nov 13, 2007 | Palm Tungsten T5 Handheld
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Interrupted update - jammed
An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
Apr 17, 2006 | Palm Tungsten T5 Handheld
Fatal Alert
Here is Epocrates answer: "... A fatal error when opening the Epocrates application typically indicates that one of our database files has become corrupt. HotSyncing again may restore functionality. If not, uninstalling and reinstalling our application should correct the problem. Other Fatal Error messages relate to not enough free memory on your mobile device for a complete installation or, your mobile device does not use the correct Palm OS version. Please verify you meet our minimum system requirements by returning to our web site, click Support, and then click System Requirements by your Epocrates application. Delete Epocrates Palm/Win from your mobild device. On your mobile device, tap the clock (located upper left corner of your screen), tap App then Delete. Select the following files (one at a time) then tap Delete. You may not see all of these files on your mobile device. It may take several minutes to delete a file. The file will disappear from the program list or your mobile device will turn off when complete. See Frequently Asked Questions 484 for instructions to preserve your notes * AutoUpdate or Libaupd * Cholesterol * Compendica * DocAlert * DocMemo * Drip Rate * Epocrates * Epocrates Dx * Epocrates ID * Epocrates Lab * Epocrates MedTools * Epocrates Rx * Epocrates MTH * Epocrates Startup * Epocrates Tables * EpoxLaunch * Fahr/Cels * HTN Ref * Insulin Calc * MedMath * MedToolsHack * MobileCME * Natrecor * OnBoardAU * Tutorial * UpdateEmail * Version-ep22 * Any file ending in NC-2 * Uncompressor * Any file starting with SMSH * Any file starting with ID and ending with NC43 Tap Done when finished. Disable the Epocrates conduit. On your computer, click on the HotSync Manager icon in the lower right hand corner of your system tray then click Custom. Double click Epocrates , select Do Nothing and check Set As Default. Click OK. Double click System, select Handheld Overwrites Desktop and check Set As Default. Click OK then Done. HotSync your mobile device to your computer. Locate and double click Epocrates2PalmW.exe to reinstall Epocrates. If you cannot locate this file, return to our web site, click My Account, login, click Epocrates Download then follow the remaining on-screen instructions. ..."
Nov 08, 2005 | Palm Tungsten T5 - Multilingual Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
