I have a motion computing tablet pc with wireless keyboard. when i press the power key on the keyboard, the led blinks continously for a few seconds rather than just four or five times and then the keyboard does not come on
    Scholar:
  • 76 Answers
Check either the batteries or the plugs
It appears your computer is trying unsucessfully to connect
Let me know if this helps
Posted on Jan 06, 2009
My motion computing battery light is not on and the machine won't start
Hold down the power button for 10 seconds then release. Then try pressing the power button again.
Apr 26, 2011 | Motion Computing J3400 Rugged Tablet PC...
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
How to reset keyboard?
Press the ID button on the receiver. LED will blink fast for a few seconds, then slower. Press the ID button on the keyboard and mouse (need a pen or something for the mouse button). Always works for me no matter which order I do them in. If receiver LED blinks whenever you mover mouse or hit key, it is receiving signal. (remember mouse sleeps after a few minutes and you have to spin the scroll wheel). If OS does not recognize on new computer, may be connectors. I had separate keyboard and mouse PS2 ports and had to use an USB adapter for the keyboard cable.
Jan 05, 2010 | Sakar 62150 Keyboard
Was working perfectly about two weeks ago--now the green timer light will not stop blinking and the unit will not turn on--I have unplugged the unit for reboot and tried the system reset to no...
Here are few items to check:
1. Check for 12 volts DC (AC-off detect) at pin 3 of PC9A21, if missing replace PC9A21 part # 268P058020 on the Power PCB.
2. LED does not blink at plug in. Check for 5-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P089010 on the Control PCB.
3.LED does not stop blinking after plug in. Check for 12 volts at connect or PF pin 10 and 28 volts at connector PF pin 11, if the supplies are correct suspect a problem in the DM Assembly (part # 955C230001)
4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 UFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with part # 181P734030 (680 uFD, 16V, 105C). See service tip VS-76
5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 4.7 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D587001
7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 935C978001
More then likely it is NUMBER 4, replace all caps if they look/check good or not.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
May 28, 2009 | Sony VAIO VGP-WKB1 Keyboard
Mitsubishi WD 52525
GOOD DAY;
THIS COULD BE YOUR PROBLEM:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
