Question about Indesit W 123 Front Load Washer
Indesit WIE167 washing mashine
I have just bought a replacement temperature sensor, can anyone tell me where it is situated in the machine?
  • Indesit Master
  • 3,463 Answers
Remove the rear panel of the washer.
You will see the heater element at the rear of the drum,it has 2 wires going to it.
The thermistor as it is called is located at the end of the element,, unplug the connector on the thermistor. and pull the old one out, refit new thermistor, and connector.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
Trx250 will not fully fire up when cold any ideas please?
Your only problem in this situation is the temperature sending unit/sensor. That's what tells the computer to put the engine into cold start mode so it will start and run. Replace that sensor.
Dec 19, 2017 | Cars & Trucks
Trouble codes p0118 temperature po118
code p0118 refers to engine coolant temperature (ETC) sensor ---circuit malfunction===causes---coolant thermostat---wiring open circuit/short to positive---wiring short to ground---ground wire defective---ECT sensor.. The temp gauge works off a temperature sender unit separate to the coolant sensor and if it is reading 100 then it indicates an overheat situation in the engine . Probably why the engine light is coming on. As the thermostat is in the list of causes I would replace it as a precaution. The coolant sensor is what tells the CPU to turn on the electric fans to cool the radiator
Jan 13, 2014 | 2004 GMC Envoy
I have Frigidaire dishwasher (model #GLD2445RFQ0), it ran great until a major brownout (thanx to a downed tree). Since then the control panel won't even light. It's as if there is a blown fuse. They tell...
Ok Ok Not so easy to answer. There are two additional functions with your current machine that not all machines are equipped with.
  • Dishwasher Turbidity Sensor
  • Thermistor Sensor
  • Sensor, thermistor and turbidity
This sensor modify s the wash cycle based on water clarity and water temperature.
Not all machines of the same group have these additional features.
Your unit does have these options.
The replacement controller( 807024501) does not have connections for these functions. The controller is basic without these enhancements, I have replaced in a similar situation a full featured controller with a less featured controller with no degradation to the dishwasher performance.
Hope this helps
Jul 02, 2017 | Dishwashers
Xps 420 air temperature sensor
I would remove your fan & heat sink to check that your thermal paste isn't dry first.
Jul 15, 2012 | Dell XPS 420 PC Desktop
The outside air temperature sensor for the 2003 Camry
the sensor is located in front of radiator if you open hood and look down behind front bumper you should see it, or look from under the frt bumper, it easy to change, also get part from dealer it not $$,hope this helps.
Nov 28, 2009 | 2003 Toyota Camry
I have a frigidaire gas oven and stove and am getting an F2 and F3 error code on the display. Can anyone please tell me wht that means?
F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 21, 2009 | Kitchen Ranges
P0128 code
Unless the car is overheating you probably just have a bad temperature sensor probably located on the intake manifold....
Apr 03, 2009 | 2002 Chevrolet Impala
Simpson encore 806 washing machine beeping and screen showing DF
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Jan 11, 2009 | Washing Machines
1995 Audie A90 Coolant Temperature Sensor replacement
It's located under the hood, driver side, upper engine area, mounted on rear of engine block behind cyl. head.
Dec 09, 2008 | 1995 Audi 90
Error 5
Error 5 refers to the temperature sensor.
On my machine the wire to it had broken at the spade connector connecting to the sensor.
You can access it easily by removing the back panel, the sensor is at the bottom of the drum with one white wire coming from it. I replaced the connector with a sleeved 1/4" spade connector bought from Halfords.
The wire is of poor quality so try to support it so vibrations dont cause the cable to fracture again
Jun 11, 2007 | Hoover HVP16 Front Load Washer
Indesit W 123 Front Load Washer Logo
213 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
