Question about Teac GF-188 Turntable
TEAC LP-R400 Turntable needs calibration adjustment...has always played to fast from day 1. Should have returned it but now warranty expired. Can calibration adjustment be done?
  • 42 Answers
Yes, both speeds can be adjusted internally, but you will have to take it to a repair shop. It is a very simple adjustment.
Posted on Jan 25, 2009
What cause of and cure for error 07 on CD of TEAC LP-R400
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 23, 2015 | Teac Audio Players & Recorders
I have a Teac LP200 and the turntable will no longer turn when I lift and move the arm over. Is there a belt to replace? How does one access it?
your unit has "The efficient belt-drive system provides accurate play and control" and normally the belt lasts for long time ..i.e at least 5 years..
If you sure that it is belt ,you need to take the turntable disc (should be a security pin in the middle ) than you can access underneath of disc or some models needs to access from bottom of the turntable ,inside the receiver..
just in case ,if you need detailed user manual in pdf format pls visit he URL below..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
User Guide for Teac LP-U200 View Table Of Contents»
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jun 25, 2011 | Teac LPU200 Turntable
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
Teac HDR2500T Fast Forward/Rewind problem: It
easy, download the software update from the teac website- had the same problem myself
Jan 10, 2010 | Televison & Video
My deck plays too fast and i must adjust pitch control to -2.5 to get the speed correct... is there a way to adjust speed internally?
this is calibrated from factory, the control board is faling check for any pot. If available, adjust a little the speed pot
Jan 08, 2010 | Stanton STR8-50 Turntable
Teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
Oct 23, 2009 | Teac GF-650 Turntable
My stanton t50 turntable plays too fast even when the pitch fader is at the slowest speed
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Oct 22, 2009 | Stanton T.50 Turntable
How to start to play
Go here for a picture:
http://www.proaux.com/TEAC-A4010-GSL-Reel-to-Reel-Recorder,name,1638,auction_id,auction_details
http://www.angelfire.com/electronic2/vintagetx/index.html
The two arrow buttons on either side of the FAST key will play it Forward or Reverse. Combining the FAST key with a direction initiates a fast forward or rewind.
May 16, 2009 | Teac GF-600 Turntable
Turntable plays too fast
I have seen this problem before. Lift the turntable off. It might be held down with a clip around the center pole. Under it you will see a wheel that contacts the turn table and the center shaft of the motor. The motor shaft has 3 0r 4 elevations with different diameters. When you change the speed the wheel will move up and down to different diameter levels on the motor shaft. It must be free to move. It might need some oil at the moving parts as I suspect it is not moving properly.
Hope this helps.
May 08, 2008 | Teac SL-A100 Shelf System
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Nov 24, 2007 | Audio Players & Recorders
Teac GF-188 Turntable Logo
339 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
