Question about Malber WD1000 Front Load Washer/Dryer
MY CLOTHS DO NOT DRY,I HAVE CHECK THE HOSES , IT DRAINS BUT THERE IS NO HEAT . I CHECKED THE FILTER THE LAST TIME AND NO WATER CAME OUT OF IT. I ALSO HAVE IT HOOKED UP TO MY KITCHEN SINK
  • jptijou Jan 10, 2009
    I'm very disappointed about my malber mmasher/dryer combo. My cloth do not dry no matter how long I leave it to dry. In addition, lot of water leak from the bottom front. It was a waste of money. I will not recommand this machine to anyone.
The same happened to mine...u might want to call for service..I was told the fuse blew out in the machine, it had to be changed because it was plugged into the wrong outlet. It needed to be plugged
into a wall outlet alone.
Posted on Jan 06, 2009
LG Electric Dryer DLE2140W, it keeps running plus no heat. It says check filter, but filter is all clear.
Dryer will only turn off when cloths are dry. Seems like you have a failed heat circuit. If electric, first reset the circuit breaker (double) a couple of times. If gas, call a tech.
Oct 14, 2015 | LG DLE2140W Dryer
WASHER DISPLAYED "OE" NOW IT WILL NOT DO THE SPIN DRY
Hi there, my mum actually had that problem with her LG washing machine, we did clean out all the drains and hoses just like you did, and also checked the pipes for any damages(cracks/ bends). Turns out the cause was that the machine just wasn't sitting level, so it wasn't draining out properly. Water just collected inside the front of the machine causing that error. Check if the machine is level, and while you're at it check your filter for clogs.
Mar 08, 2014 | Kenmore Washing Machines
Dryer not drying
Check vent if restricted in any way cloths will not dry or take a long time 3 stats can be checked other then that heat element itself maybe bad
Nov 29, 2013 | Kenmore Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
I have a Hayward Pro series Model S 180T and my pump is not pulling in the water through the skimmer like it did, therefore I am not getting the circulation in my pool like I had in the past. I checked all...
There are a few things to look at here. First is filter pressure.
Check the pressure guage on the filter . If it is at a normal pressure, you sand is probably fine, but do a 20 minute backwash anyways.
Next, are you out doors? if so, when the last time you serviced your pump. All it takes is a bad shaft seal, some pine needles, or some leaves to completely block the impeller in the pump. The is easy to check, simply remove the wet-end of the pump and look inside.
If its the shaft seal, the pump wouuld be dripping water in between the wet-end and the motor.
Also, make sure all skimmer baskets and/or main drains are clear of debris.
Also, make sure all valves are in the correct position.
If the pressure on the filter is normal, again, i wouldnt think its the filter sand.
Apr 12, 2011 | Hayward SAND FILTER, PRO SERIES
My washing machine does not empty the water from the hose, i have checked the hoses when the machine is on its spinning cycle, it only seems if a little bit of water comes out of the machine leaving the...
You need to clean the filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Reassemble and test.
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Checked drains and hoses and seems okay. drains
Have you checked the float switch inside the dishwasher. It is usually covered by a plastic piece that you have to unscrew, then after you take that off, the float will just be sitting inside of a small hole. Make sure that it is clean of all debris and build up. You can check how well it works by messing with it. Hope this helps.
Dec 28, 2009 | Dishwashers
My dryer dries for a short period time and senses that the cloths are dry before the cloths actually are dry. Can I reset the electronics some how?
no. what you are getting is an over heat sense and is shutting the unit down this is a safety type of thermostat and will shut down the heating cycle prematurely as it will with a clogged vent or lint filter
Aug 23, 2009 | Whirlpool GEW9250 Electric Dryer
Water Tank
There is a heating element much like a radiator inside the handle unit that is clogged. The water travels from the tank thru the heater and back down to the jets. You'll need to take the heater apart to clean it. You may need to check the hoses to and from the water pump also.
Jul 09, 2007 | Bissell 7950 ProHeat Upright Wet/Dry...
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
119 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
