Nedd administrative code to wipe console and use recovery cd's
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    What kind of machine is it? What code are you looking for? (Where is it asking you for the code?) Please describe in more detail what is happening...)
  • 31 Answers
Talk to the support person or put the recovery CD's in the Drive and turn the machine on. BUT understand that you WILL ERASE everything and start over from scratch
Posted on Jan 07, 2009
WHAT KEY IS REQUIRED FOR RECOVERY OF MEDION MT 7 PC
From the Setup CD-ROM
1.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
2.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
3.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console.
4.
When prompted, type the Administrator password.
5.
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
6.
To exit the Recovery Console and restart the computer, type exit.
If you have already installed the Recovery Console
1.
During Startup, select Recovery Console from the startup options menu.
2.
3.
4.
5.
Aug 15, 2012 | Medion MD-1704 PC Desktop
While trying to restore system it stops at 19% and than says says error code 0xf0000005. than when it restarts it says missing NTLDR what is that and what can i do if anything
Use Recovery Console:
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the folder containing the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
Aug 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Blue screen of death
Run the recovery console and type chkdsk /r
Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Boot from the CD
When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
Then type the chkdsk /r command
Let that run through and then restart the machine after it finishes.
If that doesn't fix it, run the Windows XP Repair Installation. You can find a walkthrough here - click here
Mar 28, 2011 | Computers & Internet
Can i386 unidrv.hlp for xp pro sp 3 be downloaded from Microsoft?
  1. Insert the Windows XP startup disk in the floppy disk drive, or insert the Windows XP CD in the CD drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD drive if you are prompted to do this.
  3. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  4. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  5. When you are prompted, type the Administrator password. If the Administrator password is blank, press ENTER.
  6. At the Recovery Console command prompt, type the following lines. Press ENTER after each line. cd system32
    ren ntkrnlpa.exe ntkrnlpa.old
    ren ntoskrnl.exe ntoskrnl.old
    cd "c:\windows\driver cache\i386"
    expand sp2.cab -F:ntkrpamp.exe c:\windows\system32
    expand sp2.cab -F:ntkrnlmp.exe c:\windows\system32
    cd c:\windows\system32
    ren ntkrpamp.exe ntkrnlpa.exe
    ren ntkrnlmp.exe ntoskrnl.exe
  7. Type exit to quit Recovery Console. Your computer will restart.
Or go to http://www.ventrilo.com/dlprod.php?id=1 and click on agree.
Nov 03, 2010 | Epson Stylus Photo EX InkJet Printer
Stop c0000218 registry failure
This will sometimes happen with a Windows XP installation when either the hardware in not compatible with the operating system...or the hard drive is damaged.
Use the recovery console to confirm that the hard disk or file system Is not damaged loadTOCNode(2, 'resolution'); Important We recommend that only advanced users or administrators use the Recovery Console.
Note Only the Administrator account can access the Recovery Console.
  1. Start your computer from the Windows XP CD drive. If prompted, select any options that you must select to start from the CD drive.
    Note To start your computer from the Windows XP CD drive, your CD drive or DVD drive must be configured to do this. For information about how to configure your computer to start from the CD drive or DVD drive, see the documentation that is included with your computer or contact the computer manufacturer.
  2. When you are prompted to select Repair or Recover, press R. This starts the Microsoft Recovery Console.
    Note You may have to enter the number to specify the Windows XP installation in the hard disk.
  3. When you are prompted, type the Administrator password. If the Administrator password is blank, just press ENTER.
  4. Use the chkdsk command-line tool to examine the hard disks. At the command prompt, type chkdsk /r, and then press ENTER.
  5. Read the results, and then take any steps that you must take to complete the process. For example, you may be prompted to run chkdsk /f to fix certain problems.
  6. Restart the computer, and then try to run Setup again.
May 23, 2010 | Dell Latitude D600 Notebook
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
XP corrupted. Safe Mode won't start. No admin pswrd for Recovery
Got a Virus? Format! It's a good occasion the delete the recovery console of Compaq HP computers. It's only a pain in the ***. Format all !
Apr 06, 2010 | Compaq Computers & Internet
Lenovo recovery through dvd
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click(or press any key) to select any options that are required to
start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer,
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the command prompt and ready to repair the ntldr file!
cd \
attrib -c ntldr
exit
Dec 29, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
AVG 7 detecdted Virus Hurri on partition table. How do I remove ?
You will need to fix the master boot record with the Windows XP Recovery Console. To do this, you will need a Windows XP install CD.
Here are the steps to use the recovery console:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
In this instance, the correct commands are:
c:\fixmbr
c:\fixboot
The type exit after finishing then remove the Original OS CD.
The machine will reboot properly.
This will fix your boot sector
And All should be well
Dec 28, 2008 | Microsoft Windows 98 for PC
Computer boot up
just worth a try if your using XP. :) using XP recovery console:
5.    At the command prompt, type the command:
chkdsk  /r
6.    When finished checking, exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Also verify that your HD has been set to master in Primary IDE and the others (if you have like CDROMS) in as slave.
Oct 28, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
David Payne
David Payne
