Question about Yahoo Messenger
I want to uninstall messenger but intall.log.file popsup what2do
Hey man i went to uninstall yahoo messenger 9.0 it got stuck at 99% i have vista i guuess the firewall wouldnt let it finish but when i go to remove it it says could not foind install.log.file pops up u got any suggestions i appreciate it
  • muripo Jan 07, 2009
    have vista when i click on uninstall it pop up INSTALL.LOG FILE...............pl give me the soluation for it.....pls..........
  • Anonymous Feb 12, 2009
    what to do ?
TRY GOING TO THE START MENU THEN CONTROL PANEL THEN ADD/REMOVE PROGRAMS SCROLL DOWN UNTIL YOU SEE YAHOO MESSENGER THEN CLICK ON THE REMOVE BUTTON. I THINK THIS SHOULD HELP YOU OUT .
Posted on Jan 06, 2009
I can not install yahoo messenger 10
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes before repairing
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Jan 03, 2010 | Yahoo Messenger
Y! messenger 9 cannot load.
Click here and download revo unistaller.
Uninstall yahoo using revo unistaller. then restart your computer and reinstall yahoo.
Thanks, Mike
Aug 20, 2009 | Yahoo Messenger
Cannot install yahoo messenger 9.0.0.2128
Vista is the key as its looking for the administrator to complete the installation
The problem may be due to a mal-function of the uninstall software.
Check
Download 'ccleaner' and run it through a couple of times.
Feb 17, 2009 | Yahoo Messenger
Installation stuck at 99% in vista h premium
i can login another yahoo ids but only the problem with shakeel_khilwath id please give me solution
Feb 10, 2009 | Yahoo Messenger
I need experienced help to uninstall yahoo messenger will not unt
try installing it and then uninstall it !
if it doesn;t work than manually remove it (should be in Program Files\Yahoo\Messenger... i think ...)
Jan 07, 2009 | Yahoo Messenger
My yahoo Im stops working
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
Dec 11, 2008 | Yahoo Messenger
I need to get my contacts back
Your contacts list is stored online, you can change versions and contacts transfer.Not sure what you mean by disconnected ( from what? yahoo,messenger,) Do this,
Dec 10, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Yahoo messenger
I also have Vista on my pc and downloaded YM 9.0 when i installed it - it stop at 99%. So I tried to uninstall it but gives me the error "cannot find uninstall log file" , so what I did was downloaded YM 8.0 and my YM was installed properly
Nov 28, 2008 | Yahoo Messenger
Yahoo Messenger Logo
62 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
