Question about Whirlpool Duet GHW9150P Front Load Washer
The control lock light is on
I went to do a load of clothes and the control lock light is lit. I've tried opening and shutting the door, disconnected the power, held the pause stop button but nothing seems to work any suggestions
  • 1 more comment
  • lmarino Jan 10, 2009
    the same situation..told to turn off breaker and turn back on...no change can't do laundry, not happy
  • Anonymous Jan 11, 2009
    I have the same problem, the control lock light is on.
  • grammyrosean Jan 18, 2009
    I H.AVE THESAME PRBLEM MY CONTRAL LIGHT IS ON,AND I CANT GET THE WASHER TO DO ANYTHING I HAVE UNPLUG I HAVE OPENEDDOOR,AND SPINNED THE THE INSIDE.I HAVE PUSHED THE CANCEL BUTTON ,PUS THE START BUTTON.I DONT KNOW WHT ELSE TO D ,AND IT IS ONLY 4YRS OLD
There is a button on the far rt of the face of the machine...you hold that button down. the button is called end of cycle signal.
ann
Posted on Jan 18, 2009
Is there a way to reset the control panel without using the control panel? And is there a way to unlock the door to get my clothes out without using the control panel?
take off the top of the machine and move the drum to the rear and using a small stubby screwdriver find the lock unscrew it to get the door open eric
Jan 01, 2018 | Whirlpool Washing Machines
How do I unlock the "control lock"
is door shut tight and locked . for sure .try leaning against the door
Oct 12, 2015 | Kenmore Elite 45986 Front Load Washer
The contol lock red light is lit and I can't get it to work
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On My Whirlpool Duet Model# GHW9150PW A setting kicked on that
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front door is locked and I cannot restart machine. Indicator light says "f d/l". How do I unlock the door?
Disconnect the machine from the outlet. Prop up the lower front edge of the machine with a block of wood or cushion the top rear edge with cloth and lean it against the wall. Remove the three screws securing the lower toe panel to the cabinet and pull it down then out.
Reach up and locate the bottom of the door latch assembly along the inside of the front panel. Gently pull down the manual door unlocking tab until a click is heard. Open the door when the click is heard.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lights went out on my bosch washer and i cant get clothes out
I unfortunately was not able to get the service manual for this machine but as far as I remember there is an internal fuse in the bosch nexxt.
Will be lokated where the power enters the machine or on the control board.
Jul 16, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Pushing Start Button only results in "Beep, beep, beep"
Need to check that the lid is shut properly and the door is locking. You don't mention an error code in the display. Make sure there isn't one showing.
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
125 people viewed this question
Dan Webster
Dan Webster
Sal De
