Typically the e70 code refers to water. so make sure that you have the hot hooked to the hot line and cold to the cold line. if this doesnt solve the problem than verify water pressure from both hot and cold sources.
You are going to need to download the Factory Service Manual for your Washer. This is a General Code, not specific to anything, You need to run the machine through it's diagnostics to determine the service code that is stored.
Once you get the service code you can narrow down and identify the issue.
Here is the Repair Manual Download Link
Thanks
