Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Brush on Dyson does not turn ....belt not broken
Power works fine ...Turn the Carpet/ Floor knob and the brush still does not turn...Any suggestions?
  • 372 Answers
Your machine has 2 belts one goes clutch to brush roller second is motor to clutch.
You need to remove the clutch unit from the machine & replace the motor to clutch belt.
Its A lot to try and explain try this site for help.
Posted on Jan 11, 2009
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brushes do not turn
HI there,
There are a couple of reasons that your brushes may not spin.
1. The hard floor / carpet dial is set to hard floor.
2. The clutch to motor belt is broken
3. The clutch to brush belt is broken.
4. The roller brush bearings are siezed.
5. The clutch is faulty.
THis sounds like a lot of things but if you watch my video I will show you all these issues and you can get your machine going again.
I also have a blog at if you have other Dyson questions.
If you need to get a new belt for your dyson or a brush roller you can purchase them online.
If this is a helpful guide please take a moment to leave a review or rating
Jan 18, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
I have a Dyson Animal vacuum - about 3 years old - and the beater bar won't turn. I can't find my manual anywhere - any suggestions as to the cause?
There is a part under the knob that adjusts from bare floor to carpet that goes bad on these vacuums. I have an animal that is about 3 or 4 years old and I had it repaired last year( to the tune of $115.00), and it broke again in December, so I just bought a new one, tired of paying high repair cost!!
Jan 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Dec 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My brush bar won't turn - works in bare floor mode, but carpet brush won't turn when it should...
replace the belt the belt sounds like its worn or stretched the belts turn at high rpms and get very hot and soon just ware out they work fine on floors but when it comes to carpet they slow down, i hope this works out thanks
Nov 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson vacuum brush bar will not rotate and the belt is not broke. The hand tool works fine. What is wrong?
I took the plate off and cleaned up the vacuum brush bar. Since the belt was not broke I knew that was not the problem. I know when the setting is bare floor, the brush bar will not rotate. That was not the problem. I just keep turning the knob from bare floor to carpet, several times. The setting must have been "off" just a bit because after several times turning it, it must have reset in the proper setting. The brush bar did start rotating just like normal.
Nov 21, 2009 | Dyson DC15 All Floors - The Ball Bagless...
My beater bar will not spin when the handle is lowered? But there's suction thru the hose when the handles upright
The motor that spins the beater bar is connected to a tiny switch, if that switch is not operating that could be the problem. If the motor is not spinning, that could be your problem (seized), or if you have a broken belt that could be your problem.
Hope this helps
Sep 25, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Not picking up and the brush does not move
Check to make sure that the knob for carpet/ bare floor has not slipped, the brushroll will only turn when carpet is selected. The most likely culprit is a stretched belt on your clutch assembly; you have one tor the brushroll and one to the motor. These belts will stretch out though Dyson will not tell you this. Best remedy is to replace the clutch assembly with OEM # 900252-04. Dyson will sell the Brusholl belt but I suggest shopping arround to find someone willing to pull the clutch apart; to my knowlege Dyson will NOT sell the motor belt.
Jan 17, 2009 | Dyson Vacuums
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Jun 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
397 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
