Question about Rio Carbon MP3 Player
Rio carbon pearl 6 gb
What does upgrade mean?
  • 883 Answers
In general, it means converting to the newest industry-standard. in the case of your device, it means flashing (re-programming) the micro or increasing memory size
Posted on May 27, 2007
How do I access the EQ section on my Rio Carbon Pearl 5 gig to change the equalizer settings?
i found the following solution:
1 Press MENU.
2 Select Settings.
3 Select Equalizer.
For more specific information follow the following link, its a manual. It answers you question on page 31.
http://www.rioaudio.com/support/rio/downloads/Carbon/RioCarbonPlaysForSure.pdf
Good luck
Dec 21, 2008 | Rio Carbon MP3 Player
Pearl rio carbon mp3 player 5gig
The microdrive is probably broken. Some people have claimed that if you give the sides a sharp tap then it has worked again but if this doesn't work then you probably require a new player. I have managed to replace the microdrive with a CF card in my Rio carbon, this has worked for many people may not work for you (you can read this: Replace broken hard drive with CF card if you want to try)
Hope this helps,
Mowcius
Oct 31, 2008 | Rio Carbon MP3 Player
Carbon Pearl: Invalid Argument
Try accessing the rio's hard drive through my computer to see if it can find the songs: they will be in a folder aptly called music within your rio carbon.
If this doesn't help then if it is picked up via my computer you could try wiping and rebooting your rio, read:
http://www.fixya.com/support/r601327-wipe_reboot_rio_carbon
You may have to change the firmware for the rio carbon pearl but this is easy to find on their website.
Hope this helps,
Mowcius
May 22, 2008 | Rio Carbon MP3 Player
Opening the Rio Carbon to replace the volume button
The easiest and least damaging way to open the Rio Carbon is to start at the bottom of the player and pry it open a little until you can see the tabs. You have to push those to release them. Work you way around clockwise and there are tab a little further into the player, you have to pull the bottom of those out to release them. I did it last night and was able to repair the volume wheel and get the player back together and it works.
Mar 29, 2008 | Rio Carbon MP3 Player
Bookmarking
you mean stop in the middle of a track and pick up where you left off? No....no such technology exists for MP3 Players.
Feb 05, 2008 | RCA TH1101 MP3 Player
RIO MP3 PEARL stuck in UPGRADER mode
Your Pearl hard drive is probably broken. This is common because they are fragile. Replacing it is the olny solution if it is broken i'm afraid. Read my post: http://www.fixya.com/support/r590688-replace_broken_hard_drive_in_rio_carbon for more info.
Hope this helps,
Mowcius
Dec 29, 2007 | Rio Cali Sport MP3 Player
No content message???
Perform a firmware upgrade as instructed on the rio website - it will wipe everything clean. Make sure the player is fully charged or this upgrade will kill the player.
Oct 29, 2007 | Rio Carbon MP3 Player
Rio carbon upgrader message
Hi Linda, Your Rio Carbon is telling you that something is messed with its firmware and it can be resolved with an upgrade. You have to determine the exact model of your unit and download the firmware from http://www.digitalnetworksna.com/support/rio/. Again you must choose the exact model. There are two ways of updating firmware updater or internet updater. complete instructions are also available. further you would need to connect your Rio to a PC to perform the upgrade. Good luck and pls post back should you need further information. Kind regards.
Aug 20, 2007 | Rio Carbon MP3 Player
Upgrader
this means that your hard disk is fucked.the best thing to do is connect it to your usb and format it.Then upgrade the software using rio;s website.hope this helps. cheers
Jan 29, 2007 | Rio Carbon MP3 Player
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
74 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
