Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
Intermittent microphone My microphone works intermittently on my parrot 3200 ls color. I can always hear the person that I call but they can hear me on some calls and not on others.
  • 1 more comment
  • Dov Barak
    Dov Barak Jan 12, 2009
    I have the same problem
    today the agent is going to replace the electronic unit (not the display)
    I will updateyou if it worked
  • gareth82 Jan 20, 2009
    Anyone found a fix for this
    Thanks
  • BigTW Feb 26, 2009
    I also have the problem - have any of you updated firmware?? Could it be 2.11d?
  • 132 Answers
SOURCE: Problem transferring contact list from BB 8330 to Parrot 3200 LS
I had the same issue with my Nokia phone a long time ago. To solve that issue I had to upgrade the Parrot's firmware with the laptop through bluetooth connection while in the car. I have done this a few times to get the most out of my parrot.
I recently got a Blackberry and had no issues with the contacts whatsoever. I do have to say that I dont have 500 contacts, but only 130.
If I were you I would try to update the Parrots firmware to the latest one available in the parrots website.
I am not sure if the parrots has a maximum contacts restriction. That might be also your problem.
Hope it helped.
Posted on Nov 26, 2009
Testimonial: "Thank you. I shall take your advice and upgrade the firmware. When (if?) I'm successful, I'll post my experiences."
  • 30 Answers
SOURCE: Parrot 3200 other party can't hear me
its the mic, try ajusting mic volume or replace the mic
Posted on Jan 17, 2010
  • 277 Answers
SOURCE: my nokia 2330 classic doesnt pair with my parrot
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Posted on Aug 16, 2010
supernova278
  • 1932 Answers
SOURCE: how do i pair my
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Posted on Oct 08, 2010
dancandoit
  • 436 Answers
SOURCE: I have just bought a new apple I phone 4. I can
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
Posted on Feb 25, 2011
Paired my nokia with my 3200 ls kit worked ok but then stoped and now my nokia cant detect my 3200 ls kit
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 23, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have just bought a new apple I phone 4. I can not get it paired to my Parrot 3200 LS. I am "told" the 3200 LS will not work with Iphone 4. The phones "sees" the parrot but on the...
Feb 03, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have a Parrot CK3200 LS-COLOR and when I make a call I can hear the person that I am calling but they cannot hear me! Any suggestions what could be the problem.
First, you will have to check if the microphone does not have a trouble.
Try to make a crossing, you call someone and you move the place of the microphone to get an idea if the trouble is still existing.
check the volume of the microphone into the menu of the kit to ensure via increasing the volume sound.
what combination of products do you have?
please inform cause it helps to find out.
Jan 04, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
No one can hear me/sound is very bad Parrot 3200
it sounds like the microphone is trapped or faulty, get the engineer back to sort it out or follow the microphone wire to see if is trapped behind the trim going down the side of the winscreen.
Dan
Feb 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Nokia 6700 classic being rejected by parrot ck3100
delete any existing paired devices from the settings menu, it may be full (5 max)
Nov 12, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Passcode for hands free parrot bluetooth device
The code is nearly always 0000, but if that doesn't work try 1234.
Mar 24, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
83 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
