Question about M20 X-Treme Radar Detector
Jammer shuts off
Hello, I recently purchased a Blinder M20 for my 95 camaro and am having a bit of a problem getting the jammer to stay on. Let me explain that in a little more detail. The power LED stays on (Green), but after about 30 seconds it beeps quickly (less then a second) and then the jammer no longer reads laser signals. It works fine for the first 30 seconds or so, but after that it won't pick up any signals. The LED remains green, but the jammers are unresposive. I've tried 3 different power sources (fuse box (horn fuse @ 25 amps), stereo lead, and finally directly to the alternator. All of these but the stereo lead put out the recommended minimum of 12.2 volts, but the problem is exactly the same. I've tried switching the ports on the receiver box and it does the same on all 4. I've tried it with and without the auto mute, same story. I use the IR from a TV remote control to test the jammers, which again work fine for the first 30 seconds or so, but the problem continues to return. I've got it hooked up with the lead running to the middle switch on the back of the power switch and the lead running from the top connection on the back of the switch to a power source. Any help would be appreciated. Thanks!
  • igorm83 Jul 27, 2008
    i have the same problem
To my understanding,the first 30 seconds is a test mode when the blinder will react to a tv remote,after wards the light will remain green until a true laser attack.
Posted on Jul 04, 2007
How to find an audio jammer that is located on my property but I don't know where.
Call a friend from where it can here u.Start walking till it cant here u no more,Step back untill it can here u again .Repeat from other position till u get a circle.In the middle u should have your jammer depending of the buildings/geografy and other obstacles.
May 20, 2013 | Vehicle Parts & Accessories
Tip
Customize your computer
<p>To personalize ones computer is to make a statement of command and power,<br /> <p><span> </span>So here's a neat trick :: start/run/intl.cpl will open up the regional language options.<br /> <p>Then click on the customize button and select the time tab. In the AM and PM section you can add text like mine says { AM DJ Jammer..PM DJ Jammer) <span> </span>or any other<span> </span>text<span> </span>and select ok<br /> <p>Now down at the task bar after the time your message/logo will appear.<br /> <p>Enjoy
on Aug 18, 2011 | Computers & Internet
What can happen if I use a GPS jammer?
The operation of a jammer in the United States and in most of the countries is illegal and may subject you to substantial monetary penalties, seizure of the unlawful equipment, and criminal sanctions including imprisonment.
Feb 06, 2013 | Home Security
Can mobile network jammers block bluetooth
It depends upon what type of mobile network jammer/blocker you have. many mobile network Jammar are not able to jam the Bluetooth device or Bluetooth of mobile phone.
3G 4G Cell Phone Signal blocker Mobile Signal Jammers Device
Jan 28, 2013 | Cell Phones
How does a mobile network jammer work
A mobile phone jammer is an instrument used to prevent cellular phones from receiving signals from base stations. When used, the jammer effectively disables cellular phones. These devices can be used in practically any location, but are found primarily in places where a phone call would be particularly disruptive because silence is expected. A cell phone signal jammer is used to stop nearby cell phones from sending or receiving signals to and from the cell phone tower. A cell phone works by communicating with its service network through a cell tower or base station. Cell towers divide a city into small areas, or cells. As a cell-phone user drives down the street, the signal is handed from tower to tower.
Cell phone jammers block cell phone use by sending out radio waves along the same frequencies that cellular phones use. This causes enough interference with the communication between cell phones and towers to render the phones unusable. On most retail phones, the network would simply appear out of range. Most cell phones use different bands to send and receive communications from towers. Jammers can work by either disrupting phone to tower frequencies or tower to phone frequencies or both.
Cell phones are full-duplex devices, which means they use two separate frequencies, one for talking and one for listening simultaneously. Some jammers block only one of the frequencies used by cell phones, which has the effect of blocking both. The phone is tricked into thinking there is no service because it can receive only one of the frequencies. The jammer also stops Internet use through Wi-Fi network and even blocks Bluetooth connections. The cell phone signal jammer also puts an end to text messaging, so students cannot SMS each other, while the teacher is trying to teach.
Interestingly, jammers are life saving devices for military. Terrorists use cell phones to trigger explosives. Army can use a jammer to make mobile phones go dead, so that army technicians can deactivate the bomb.
What are some good mobile network jammer providers in Delhi
1) Innovatiview
2) mobilejammer
3) electronics.howstuffworks
Innovatiview is the best supplier among them. It is Delhi based but has a strong distribution channel throughout India. Their jammers have been used by many schools, colleges and industries. They have a wide range of jammers and their customer service is fast and reliable. I heard that they work closely with the Government organizations and offer customized solutions to conduct cheating free exams.
The clock in my pc not work staying 1 january 2003 and my pc open with f1
you have a bad battery on the motherboard it is a 2032 button type that can be purchased at most hardware/ supermarkets. or www.tigerdirect.com as one of many sites that sell them.
it is simple to replace(no tools needed) and should be done while power is disconnected.
then hit del/f2 depending on the system and enter bios. and set the correct date and time.
problem should go away.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 31, 2011 | HP Compaq Presario F500 F700 and G6000...
Mijn cursortoetsen werken nie op mijn psp wat moet ik doen
Ek is jammer as jy nie verstaan nie, ek is met behulp van 'n vertaler. Ek neem aan jy verwys na die web browser, jy het analoog stok te gebruik om die te opgevolg, terwyl die gebruik van die webblaaier. Jammer weer oor die vertaler.
Oct 03, 2010 | Sony PlayStation Portable (PSP) Console
Can i block a incoming call 4m a particular number in NOKIA 5130????? plz mail me d soln @ debrajjana2009@gmail.com
Download iMobileTool Incoming Calls Blocker 1.51 from the below link and block the number you want with this software
http://www.topshareware.com/free-call-blocker-nokia-5130/downloads/1.htm
May 30, 2010 | Nokia 5130 Cellular Phone
Removing vehicle locator from my dodge caravan
An easier way is to get a gps jammer. They make nice ones for cheap. Check the import sites from china. They make a small unit that plugs into cig lighter socket, and is no bigger than your thumb.
http://tayx.manufacturer.globalsources.com/si/6008827809982/pdtl/Security-products/1006202554/Car-GPS-Tracker-Jammer.htm
or
http://www.google.com/search?hl=en&source=hp&q=china+Car+GPS+Tracker+Jammer&aq=f&oq=&aqi=
Apr 15, 2008 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
197 people viewed this question
Top Blinder Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Blinder Vehicle Part and Accessory Expert? Answer questions, earn points and help others
