Question about Nikon COOLPIX L3 Digital Camera
Lens cover doesn't open
Recently for no known reason, when I turn the camera on, the lens extends, but the lens cover shutter doesn't open. If I give it a light tap with my finger the shutters open up, but what a pain. Any suggestions?
  • George Thomas May 29, 2007
    Actually, I put just a tiny drop of Tri-Flo on the shutters and after cycling through them a bit, they now open a lot more smoothly.
  • 883 Answers
There is a misalignment in the shutter flaps and must be re-aligned by an experienced tech.
Posted on May 27, 2007
How to disassemble lens on a casio exilim ex-z75
Jim, I really wouldn't recommend this. It requires extreme patience and meticulous parts tracking. Note that junctions stated: "It's really hard to take apart,", and he ain't kidding.
Really recommend that you return to the remedies that you had been trying. Sometimes it requires many repeated tries to free the gunk from the shutter. I've found that for the smaller pocket cameras that the most effective solution seems to be extending the lens and tapping around the lens barrel with a pen/pencil. Then alternately opening the battery door with the camera turned on (no need to play with shutter modes). Then just alternate with tapping, battery door, tapping, battery door, and keep doing this until the shutter opens/closes. Once this happens, set the camera to continuous shutter mode and snap off about 100 pictures to final lubricate the shutter.Good Luck,t00nz aka CR
Nov 22, 2011 | Casio Exilim EX-Z750 Digital Camera
Shutter is not opening in PL-90
A stuck automatic lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it:
METHOD 1:
Point the camera straight down into a vacuum hose (while the vacuum is on) and tap it around the insides. This will help to **** the dirt out instead of pushing it in further like compressed air might do.Also turn the camera on and off constantly while doing this.
METHOD 2:
1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible.
2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degrees to clear out any debris that may be in there.
3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work then it may be necessary to open the lens barrel to access the lens cover mechanism.The lens cover mechanism is usually accessible for many cameras without needing to open up the camera case.
May 31, 2011 | Samsung PL90 Digital Camera
Lens gets stuck,and makes a clicking noise when trying to open
Hi
Thanks for using FixYa. With the camera closed and off point it straight up (lens towards the ceiling) and hit the power button while holding down the shutter release. When the camera opened, it immediately tried to focus for the picture it was told to take, and apparently it forced the lens to move.
You can also try blowing compressed air around the lens cover to clean it. Now slide a thin strip of paper between the lens cover shutters and the outer support ring and move it around 360 degrees. This will clear the debris stuck there.
With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat these steps several times to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 04, 2010 | Samsung S1050 Digital Camera
Lens cover will not open
easy fix. yo turn it on and then very lightly tap the lens cover or push it out. then you should clean the lens because the dirt or dust on the lens is stopping the lens cover.
Aug 24, 2009 | Canon PowerShot A530 Digital Camera
Shutter does not open
The camera does not gets opened on power on it seems that some gear has broken inside
Feb 27, 2008 | Samsung Digimax A400 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Camera lens cover is sticky
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Lens cover jamming
Aug 28, 2006 | Samsung Digimax 250 Digital Camera
Kodak DX6340 Lens Cover Does Not Open
Aug 13, 2006 | Kodak EasyShare DX6340 Zoom Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
179 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
