Question about Dell Dimension 2400 PC Desktop
Replacement DVD-ROM door stuck close would like to replace the unit, what would be a good unit to replace it with Thank you billabob
  • Dan rogers
    Dan rogers May 11, 2010
    what exactly are you asking? Do you want to go with blue ray or just a cd burner or are you asking for a reccomendation for a dvd rom?
    Problem Solver:
  • 6 Answers
Any 3.5 drive should work its all up to your tastes... really computers arent that picky when it comes to most drives... in fact most drives are just plug and play.
Posted on Jan 06, 2009
My dvd rom drive does not spin.
Do other functions operate? (door open/close, etc)
Unfortunately, due to the construction of optical drives, they really can't be disassembled for inspection or repair. You will most likely have to purchase a new drive and install it. You can get a quality replacement for less than $25 from newegg.com.
If you are dealing with a laptop drive, most are, unfortunately, manufacturer specific, and tend to be a bit more expensive.
May 12, 2011 | Lenovo 16x DVD-ROM Drive - 1 x Serial ATA...
Cd rom drive door will not stay closed. i close it and then seconds later its back open again.
There's a little piece of plastic or metal that's connected to a sprin which clicks into place when you close the dvd drive and keeps it closed. Either the spring or the plastics is stuck or broken. They're very easy to replace and used ones don't cost much
Jan 15, 2011 | HP Pavilion G60-235DX notebook
Internal CD ROM will Not Open
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Dec 31, 2008 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
Bose 321 DVD drive failure
Found another help site similar to FixYa where a person had posted that they successfully replaced their failed DVD ROM drive in their BOSE 3-2-1 Series I unit with a later model Toshiba SD-M1712 drive. There are 2 plastic trim bits and the metal DVD drive unit cover that need to be swapped between the old drive and the new PC type drive to complete the repair. I located and ordered a new drive and spent last evening removing the old drive from the BOSE. To remove the old drive all that is really necessary is to remove the lid from the BOSE unit and pop off a black steel holdown assembly across the top of the failed drive. Once that is done the old just drive lifts out and the replacement is virtually the same as swapping out a drive in your PC. I am awaiting arrival of the replacement OEM drive ($25) from some place in Texas. This just may work. BOSE wants hundreds of bucks and several weeks to repair their crappy unit. I will never purchase BOSE again. I had to also purchase a power supply in years past for this very lightly used unit and that was $300 and a lot of aggravation using the BOSE repair system. I have trouble just throwing this unit away because we spent $1000 hard earned $'s to buy the "best". I was certainly fooled. If this doesn't work I'm only out $25.
Dec 09, 2008 | Bose 3 2 1 GSX System
DVD-ROM
LS-120 SuperDisk drive help The LS120 will not work off a sound card IDE channel. ... If the computer is on, however, does not eject and you are running Windows 9x.
CD-ROM tray not opening See document CH000885 for additional information about why the CD-ROM or other disc tray ejects by itself or does not close.
CD or other disc tray does not close or opens by itself.
Good Luck, read and folow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | Toshiba A15-S1292 Notebook
Will not read DVD-ROM
Computer DVD Support.
Good Luck, Please dont for get to Vote, Follow instructions.Thank you.
Dec 26, 2007 | Compaq Armada M700 Notebook
Disc door will not open
Open the unit and remove the DVD manually. The magnet that holds the DVD in place is stuck to the top cover.
Nov 29, 2007 | Lite On LVW-5005 DVD Recorder
Emachines w3507 DVD Rom Broken
There may be a hole but it will be under the lip of the door, kind of impossible to get to. You may have to remove the drive from the emachine and unscrew it and open it manually with a small screwdriver. I regularly buy and repair or use parts from used samsung drives which is what emachines uses almost exclusively. The only upside to this is that once open, you can swap the faceplates and doors onto newer drives. If the led light is not in the middle then you can swap out the little plug in circuit too.
Nov 12, 2007 | E-Machines emachines (emachinees) CD-ROM...
Dell Dimension 2400 PC Desktop Logo
21 people viewed this question
Alun Cox
