Question about Onkyo DV-CP500 Multi-disc DVD Player
DVD player stuck in standby mode
My DVD player is stuck in the standby mode. I can turn the power on and off but when I turn the player back on, the standby light blinks and it stays in the standby mode. I have disconnected the power cord completely and reconnected trying to "reboot" but this hasn't helped either. I'm not sure how long ago this started or the circumstances that created this situation. Thank you.
  • 5 more comments
  • jp515 Nov 25, 2007
    Stuck in standby mode
  • Anonymous Dec 09, 2007
    Same exact problem, stuck in standby with discs in.  Have tried to disconnect and reconnect, and reboot.  Nothing has worked.  Also, I note that it has somehow become disconnected from the tuner, although it is still connected to the TV.
  • Anonymous Dec 28, 2007
    stuck in standby have tried reboot, no luck.
  • Anonymous Dec 30, 2007
    I have the same problem
  • sonax Jan 16, 2008
    I have the same problem and thought maybe a disc was stuck inside.No one remembers using it recently. The red light flashes but will not come on into a play mode. I've unplugged the power and disconnected all of the cables and then retried still the same problem.
  • Anonymous Jun 09, 2008
    UNPLUGGED TO REBOOT BUT IT DIDNT WORK
  • Anonymous Mar 23, 2014
    won't come on green light for standby mode is on but doesn't do anything when trying to turn on. It stays off, and light stays solid
  • 56 Answers
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
Posted on Jan 22, 2008
  • 4 more comments
  • Jambam Jan 22, 2008
    ooops meant C7 (10v, 470uf) NOT C17.
  • Jambam Apr 12, 2009
    Seems like a manufacturing defect with the way C005 on the Mechanism Control Board was mounted. The postive lead hole on the circuit board for this electrolytic capacitor wa drilled into a land that was too narrow for the lead size. The result is no +B to the motor control IC's(LB1641's) on this board. Jumper with a suitable wire from the positive lead on C005 to pin 7 or 8 of the LB1641.
    This should have read "Bad caps in the power supply is causing this. C7 (10v,470uf), C14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great. However It think the problem most folks are having is with no B+ (9 volts) going to the LB1641 IC's that control the carousel and platter motors due to C005 positive lead hole cutting through it's land almost entirely. Jumper from C005 positive lead to Pin 7 or 8 on LB1641.. this fixed my unit for good. No more weirdness with opening and reading etc...
  • gth1645 Dec 12, 2010
    You guys are great! Can someone tell me where C005 is? And which board is LB1641
  • Jambam Dec 13, 2010
    Hi gth1645.. the circuit board you are looking for is under the carousel. It's the motor control board. Capacitor C005 and Integrated Circuit LB1641 are on that Board. There are 4 screws that hold the carousel in place located at each of it's four corners. You will also need to disconnect about 5 connectors (3 on the power supply board ; 2 on the main board going to the rear output board. You will also need to pop the power switch button mechanism off the power switch that is on the power board. Once you've done this you can pull the carousel out , turn it upside down and you will be staring directly at the long narrow carousel motor control board. Remove the board and you will see C005 labeled and IC LB1641 labeled. Use a DVM or VOM and see if you have continuity between C005 positive lead and Pin 7 or 8 on the LB1641 IC. No continuity means that you have found the problem , please make sure you are on the positive lead of C005. Solder an insulated small gauge braided wire between the positive lead of C005 and Pin 7 of LB1641.
    Reply
    New Friend:
  • 4 Answers
Try this: Hold in the StandBy/Power button do not un-press it this entire time. While pressing in StandBy/Power button then unplug the unit/DVD CD player from outlet and CONTINUE to press in StandBy/Power button. Holding StandBy/Power button for a full minute to minute and a half while unit is unplugged. After the full minute to minute and a half then let go of StandBy/Power button. After you have let the StandBy/Power button go (unpress) then plug the unit back into the outlet. It should now come out of the Stand By frozen mode and the drawer for DVD/CD should open when you press eject and the unit should work again. Worth a try.
Posted on Apr 06, 2015
DVD player stuck on standby
There is a problem in the power supply caused by one or more open capacitors, in some cases they develop a bulge at the top making it easier to find.
Apr 21, 2012 | Televison & Video
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
May 27, 2010 | Sony KDL-32S3000 32 in. LCD Television
Need code to Dish Network Remote Control for Sharp DVD Player DV-S1U
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 20, 2010 | Sharp DV-S1U DVD Player
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Jun 02, 2009 | RCA DRC8335
DRC277a red light only
The red light on my player is on when the unit is off and it is on when in the standby or play mode.
Jan 14, 2009 | RCA DRC277 DVD Player
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Onkyo DV-CP500 Multi-disc DVD Player Logo
5,505 people viewed this question
Top Onkyo Televison & Video Experts
Steve
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
