Question about Uniden BC248CLT Base Scanner
Will Scan But Picks No No Transmissions
When i have the scanner scanning it will scan but will not pick up any transmissions. i have another scanner that will pick up transmissions but the bearcat wont. i have tried moving the antenna but it does nothing. i am getting frustrared and dont know what to do. please help!
  • Anonymous Nov 11, 2008
    my scanner will not do nothing it scans but no transmit
Call the company and get a new one
Posted on Jul 10, 2007
Why do i have a white strip down my scan
CHECK TO SEE IF THERE IS ANY DEBRIS ON THE SCANNING ROD THAT PICKS UP IMAGES.... THAT WILL CAUSE THE WHITE LINE.
Jul 10, 2014 | Generic VuPoint Magic Wand PDS-ST415-VP...
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
Scanner is not picking up anything
it should have a squelch knob . Turn it all the way up and try your scan again. Also turn your volume up a little.
Jan 13, 2013 | Uniden Bc125at Handheld 500 Ch. Special...
Wont pick up any transmissions
If you scan for activity and don't hear any, there may be no activity in your area. Also, many services are moving to digital
Sep 22, 2012 | Uniden Radio Communications
My Radio Shack Pro-82 Scanner is not working at all.i turned it on and it wont even scan. i cant even hear the squelch. and the only time it picks up something is when its on the air setting it picks up...
Ok I have had the same problem with the Pro 82 and the biggest problems I've found for it not to scan is Corrosion of the terminals not only outside but inside. Even on the keypad and pcb board. SOLUTION: Just take it all apart with a small philips pecision screwdriver and with a dry toothbrush scrape all the corrosion off the board. This always solves my problem and it should yours. Even if theres no corrosion visible on the terminals be assured there is still some inside keping this from functioning correctly. Shotgun420
Jul 30, 2011 | Radio Shack Pro-82 Scanner
BC72XLT scanner does not stop on some programmed channels while scanning. My other scanner will read the transmission. The numbers indicating banks 1 and 3 aare not visable during scan, are they locked...
what it is because that your other banks are locked out and thats why it by passes your frequencies...unlock your banks and it will stop on the transmissions...
Apr 01, 2011 | Uniden BC72XLT Handheld Scanner
It just scans and scans it never picks anything up. No clue how to work this scanner or where to get codes for it. When you turn it on, it just scans thru all the channels but doesn't seem to pick anything...
Sounds like either your squelch is set too high or you don't have the proper frequencies for your area programmed into the scanner. When it starts scanning turn the squelch down gradually until the scanning stops and you hear noise, then turn up slowly until it starts to scan again. If you still don't pick up anything, you probably need to reprogram the frequencies. For a list of active frequencies and systems in your area visit
www.RadioReference.com
or
www.CityFreq.com
In case you need it, here's a link to the manual for your scanner.
If you have any other questions, please contact us again.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Radio Shack Pro-2051 Base Scanner
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Jan 09, 2009 | Computers & Internet
How to scan frequencies quietly
Yes...adjust the squelch control. This is usually a knob adjacent to your volume control. This should eliminate the static noise and you will only hear audio when someone is transmitting.
Nov 17, 2008 | Uniden BC72XLT Handheld Scanner
Uniden BC248CLT Base Scanner Logo
299 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
